Results 1 to 6 of 6
Thread: HELP...AutoCAD Crashes When Plotting
    2015-09
    408
    Question HELP...AutoCAD Crashes When Plotting
    Hello To All AUGI Members:
    We are experiencing a strange problem with our drawing files when we attempt to plot a drawing that contains a polygonal viewport (6 sides) to any of our HP "pc3" plotter devices. In our West coast office they have an HP DesignJet 1050c and other HP laser Jet printers and when they try to plot a drawing with the multi sided viewport AutoCAD begins to make the plot but approximately 75% through the process AutoCAD simply crashes without any warning.
    When they attempt to send a plot to another plotter device (JDL plotter, Canon printer, etc.) the drawing plots fine with no problems.
    Has anyone seen this problem before and if so is there a work around or fix I can apply to resolve this problem...??
    Any assistance would be appreciated.
    Regards,
    Vince
    13,625
    Question Re: HELP...AutoCAD Crashes When Plotting
    Hi
    Are you Plotting via Windows or Heidi Drivers?
    Do the Polygonal Viewport boundaries consist of complex linetypes?
    Have you tried running an Audit, Purge and Recover on all the drawing files?
    Have a good one, Mike
    2015-09
    408
    Default Re: HELP...AutoCAD Crashes When Plotting
    Mike:
    The drawing files have been Recovered, Purged and Audited and the viewport boundary is just a 6 and sometimes an 8 sided polyline.
    The driver is the hpgdi8.hdi, Version 1.1-8.0 16.86
    Any suggestions...??
    13,625
    Quote Originally Posted by vferrara
    Hi
    Try Plotting via the HP Optimized Windows Driver, if you have not got this Driver go the Hewlett-Packard web site -
    HP - Software & Driver Downloads
    Maybe look at this if using AutoCAD 2004 -
    ID: DL404084 - hpgdi8.hdi Service Pack 1 Update
    ID: TS81831 - Installing Service Pack 1a if Service Pack 1 was previously installed
    Last edited by Mike.Perry; 2005-06-28 at 09:20 PM. Reason: Correct bad formatting.
    2015-09
    408
    Mike:
    We are currently using AutoCAD 2005. Would the HP patches for 2004 also apply for the 2005 version....??
    Regards,
    Vince
    13,625
    Hi
    Nope! there are strictly for AutoCAD 2004.
    If you haven't applied Service Pack 1 to AutoCAD 2005, you could always give that a go...
    AutoCAD 2005 Service Pack 1
    Have you tried Plotting via the HP Optimized Windows Driver?
  1. Plotting Raster processing in version 9 Crashes
    By Baldwin_4-6-0 in forum Revit - Plotting/Printing/Exporting
    Last Post: 2014-08-13, 07:34 PM
  2. 2014: Revit Crashes when batch plotting to a color PDF
    By kmarquis in forum Revit Architecture - General
    Last Post: 2014-05-12, 04:29 PM
  3. 2011: ACA 2011 randomly crashes when plotting dwg to pdf
    By Ken Neitzke in forum ACA General
    Last Post: 2010-07-02, 05:06 AM
  4. crashes mostly while plotting??
    By smcmillin in forum Revit - Plotting/Printing/Exporting
    Last Post: 2009-11-11, 03:47 PM
  5. Plotting to Designjet 500ps crashes CAD
    By Statler in forum AutoCAD Plotting
    Last Post: 2005-07-21, 10:43 AM
