I have one drawing that is giving me a lot of grief. I can't seem to change the dim text height no matter what I do. This is true for new dimensions and editting existing. The properties in the dialog box change, but the actual size does not. Example, I'll set the dim style text height to 2" then dimension a segment. The text will be 1" but the properties dialog box shows the height as 2". Does not matter what the properties say, the text remains 1". Everything else can change, arrow style and size etc. There is not a problem with regular text, just dim. It is only happening with 1 dwg, could something be locked?
