Results 1 to 10 of 18
Thread: Dimension text height won't change
    2005-05
    9
    Default Dimension text height won't change
    I have one drawing that is giving me a lot of grief. I can't seem to change the dim text height no matter what I do. This is true for new dimensions and editting existing. The properties in the dialog box change, but the actual size does not. Example, I'll set the dim style text height to 2" then dimension a segment. The text will be 1" but the properties dialog box shows the height as 2". Does not matter what the properties say, the text remains 1". Everything else can change, arrow style and size etc. There is not a problem with regular text, just dim. It is only happening with 1 dwg, could something be locked?
    2001-05
    Austin, TX USA
    2,201
    Default Re: Dimension text height won't change
    In the text style dialog, change the height of the style you are using for the dimensions to "0". This will allow the the dimension dialog to change text height.
    2005-05
    9
    Quote Originally Posted by gpope
    I already did. No go.
    Thanks anyways
    13,656
    Hi
    Please post the drawing file that is exhibiting the behaviour you describe above.
    Have a good one, Mike
    2005-05
    9
    Here's the messed up dwg.
    13,656
    Hi
    DimStyle "new" and "Standard" both use Text Style "Standard".
    Go to the Text Style dialog box (command ._Style) -> from the "Style Name" drop-down list pick "Standard" -> now do as Glenn suggested (refer to attached screen capture, shows current settings for Text Style "Standard)).
    2005-05
    9
    "Thud, thud, thud" That's the sound of me kicking myself!!!
    Thanks for the help!
    For the engineer the glass is never half full or half empty, it's just twice as big as it needs to be.
    2011-02
    5
    Once I change the style height to 0, all is fine. However, when I close and later re-open a drawing, the style height is back to .125. Why isn't AutoCAD remembering the settings? Thanks
  1. Lock Text Height in Dimension Style when Text Style Height is Not 0
    Last Post: 2013-01-16, 04:55 AM
  2. Global Text Height Change - With MText & DText
    By omorah in forum AutoCAD General
    Last Post: 2011-10-04, 05:43 PM
  3. Wanting Height of Text Within a Detail Component to Change With the View...
    By dlancor in forum Revit Architecture - General
    Last Post: 2008-02-12, 04:57 AM
  4. Replies: 2
    Last Post: 2007-04-17, 03:08 PM
  5. Cannot change dim text height
    By neilcheshire in forum AutoCAD General
    Last Post: 2005-10-13, 04:53 AM
