Results 1 to 8 of 8
Thread: Octagon Window Size Parameter
    2003-01
    Yulee, FL
    184
    Default Octagon Window Size Parameter
    I have made a nice 2' octagonal window family (the octagonal window from the Revit Autodesk site is a hex after all) with grids that I can turn on and off. I would like parameters to make its size adjustable (say 1' or 3' or whatever) but after many many hours I just can't seem to make it work. Could this be a rare instance outside the capabilities of Revit or is it my abilities in question?
    Bill Maddox
    AUGI Addict aggockel50321's Avatar
    2003-05
    Waterville, Maine
    1,748
    Default Re: Octagon Window Size Parameter
    Here's a parametric octagonal opening, that might give you a starting point.
    2003-01
    Yulee, FL
    184
    Thanks so much andrewg. That is a huge help. I'll work on it this weekend and give an update. Thanks.
    2003-01
    Yulee, FL
    184
    Andrewg:
    Got the window done with your help. Don't know how to attach it to this message but if you want a copy I will be happy to e-mail it to you. My e-mail is zenomail@aol.com.
    Thanks again
    Bill Maddox
    All AUGI, all the time Elmo's Avatar
    2005-04
    South Africa
    959
    Hi there guys after seeing your Octagonal Windows and openings I tried to see if I could maybe simplify the process a little.Here is my Octagonal opening. zenomail you can add a file when you are in the the advanced section for replies by managing attachments
    2003-01
    Yulee, FL
    184
    Yes Clinton it does simply things. I am studying it. Thanks
    Also thanks for the advice on attachments. I am trying it out with my Octagon. Voila!
    Bill Maddox
    2005-04
    South Africa
    959
    Impressive zenomail.I like what you did with the family.Just a couple of suggestions though make the glass thinner and make it fit the in the mullions and lock it to them.If you want to change the material parameters in the family select the object(like a mullion) go to it's properties and where you would give it a material select the little grey box next to it and make it into a parameter.
    2003-01
    Yulee, FL
    184
    Thanks Clinton. Happy days!
    Bill Maddox
  1. 2013: 'Pipe Size' Parameter Can't Be Used
    By TerribleTim in forum Revit MEP - Families
    Last Post: 2013-06-14, 01:54 AM
  2. Sheet Size Parameter
    By rudolfweyers346383 in forum Revit Architecture - General
    Last Post: 2010-11-10, 01:38 PM
  3. Holes have octagon look - not round?!?!?! Help!
    By cadlivin in forum AutoCAD 3D (2007 and above)
    Last Post: 2008-03-24, 06:04 PM
  4. DWG size factor as parameter??
    By Martin P in forum Revit Architecture - Families
    Last Post: 2006-02-02, 09:07 AM
  5. Octagon Roof question
    By a.quinn1833 in forum Revit Architecture - General
    Last Post: 2004-01-14, 05:11 PM
