Results 1 to 8 of 8
Thread: Octagon Window Size Parameter
    2003-01
    Yulee, FL
    184
    Default Octagon Window Size Parameter
    I have made a nice 2' octagonal window family (the octagonal window from the Revit Autodesk site is a hex after all) with grids that I can turn on and off. I would like parameters to make its size adjustable (say 1' or 3' or whatever) but after many many hours I just can't seem to make it work. Could this be a rare instance outside the capabilities of Revit or is it my abilities in question?
    Bill Maddox
    AUGI Addict aggockel50321's Avatar
    2003-05
    Waterville, Maine
    1,748
    Default Re: Octagon Window Size Parameter
    Here's a parametric octagonal opening, that might give you a starting point.
    2003-01
    Yulee, FL
    184
    Thanks so much andrewg. That is a huge help. I'll work on it this weekend and give an update. Thanks.
    2003-01
    Yulee, FL
    184
    Andrewg:
    Got the window done with your help. Don't know how to attach it to this message but if you want a copy I will be happy to e-mail it to you. My e-mail is zenomail@aol.com.
    Thanks again
    Bill Maddox
    All AUGI, all the time Elmo's Avatar
    2005-04
    South Africa
    959
    Hi there guys after seeing your Octagonal Windows and openings I tried to see if I could maybe simplify the process a little.Here is my Octagonal opening. zenomail you can add a file when you are in the the advanced section for replies by managing attachments
    2003-01
    Yulee, FL
    184
    Yes Clinton it does simply things. I am studying it. Thanks
    Also thanks for the advice on attachments. I am trying it out with my Octagon. Voila!
    Bill Maddox
  1. 2013: 'Pipe Size' Parameter Can't Be Used
    By TerribleTim in forum Revit MEP - Families
    Last Post: 2013-06-14, 01:54 AM
  2. Sheet Size Parameter
    By rudolfweyers346383 in forum Revit Architecture - General
    Last Post: 2010-11-10, 01:38 PM
  3. Holes have octagon look - not round?!?!?! Help!
    By cadlivin in forum AutoCAD 3D (2007 and above)
    Last Post: 2008-03-24, 06:04 PM
  4. DWG size factor as parameter??
    By Martin P in forum Revit Architecture - Families
    Last Post: 2006-02-02, 09:07 AM
  5. Octagon Roof question
    By a.quinn1833 in forum Revit Architecture - General
    Last Post: 2004-01-14, 05:11 PM
