Hi,
I need to know if it's possible create a roof between this six point?
I try using the slope Arrow but without any result, any suggestions?
Hi,
Ricardo,
There may be a better way but the easiest solution is to create an in place roof blend (or two blends, one for each side). If created as a roof you can then attach the walls to the underside of the roof.
The problem is that the two walls that have the slope are not parallel.
See the example attached.
There are probably many ways to do this roof. What I did is made an extruded roof and then used void extrusions to cut out the overhangs so they were parallel to the walls. Hope this gives you some ideas.
