Results 1 to 10 of 17
Thread: Unable to Open a drawing file
    2005-03
    57
    Default Unable to Open a drawing file
    hello,
    I've got problems with opening my drawing.
    I opened the drawing Saturday for the last time.
    When I now try to open it the error says.
    "drawing file is not valid"
    But the preview when opening shows me the last save I made.
    Can somebody help me with this problem
    Thank you
    greets
    Maarten
    Certifiable AUGI Addict Wanderer's Avatar
    2001-12
    St. Louis
    4,260
    Talking Re: Unable to Open a drawing file
    Quote Originally Posted by mwittens
    hello,
    Thank you
    greets
    Maarten
    have you tried to 'recover' the drawing?
    do you have this problem with other drawings?
    can you post it so someone can take a look?
    Melanie Perry @MistresDorkness
    Facilities CAD Management (FM - MEP/FP)
    Technical Editor
    Revit MEP 2013 Suite
    not all who wander are lost
    2005-03
    57
    Default Re: Unable to Open a drawing file
    yes i've tried to revover it.
    where can I post the file?
    It is just above 2 mb
    2001-12
    St. Louis
    4,260
    when you are replying to the message, you can scroll down until you see 'additional options' and there is a button for 'manage attachments' you can load your file into your post that way.
    I don't recall the file size limit offhand, but, you can always zip the file prior to posting if it is too large...
    Technical Editor
    2005-03
    57
    the max file size is 1mb.
    maximum compressing gives me 1,6 mb.
    can I mail it to you
    All AUGI, all the time bbapties's Avatar
    2003-12
    Palm Harbor, FL
    537
    did you actually try to zip and post it... I've seen zipped files of dwgs over 3 megs posted on here....
    Certifiable AUGI Addict Robert.Hall's Avatar
    2004-07
    Detroit Michigan
    2,510
    I am guessing that you are basically "out of luck".
    I had a similar problem and found that I had an .arx file that froze up AutoCad and left a bunch of unwanted code in my drawing file. I had a .5mb file balloon to 2mb.
    I pretty much lost a days worth of work after the IT department retrieved an older version of the file from a previous backup tape.
    I tried everything from recovery tools, batch purging, opening in Inventor instead of AutoCad, and even using a file translation tool to transfer to an iges file. Nothing seemed to work, however, Inventor seemed to open the file. The inventor file wasn't usable.
    2001-03
    13,499
    Hi
    If you are unable to post the drawing file here within the forums, please feel free to E-mail the file directly to myself.
    I can't promise anything, but I will take a look and try my best...
    Have a good one, Mike
    2005-03
    57
    Quote Originally Posted by bbapties
    I tried winrar I like that one more. compress type best and 2,3 turned in to 1,6.
    2005-03
    57
    Quote Originally Posted by Mike.Perry
    Hi
    ok mike i've sent you a mail.
    good luck
  1. Replies: 13
    Last Post: 2010-07-09, 11:58 AM
  2. Unable to Open Drawing
    By dillarm in forum AutoCAD General
    Last Post: 2010-05-27, 02:18 AM
  3. AutoCAD 2008 unable to open a drawing file that crashed
    By gregoran in forum AutoCAD General
    Last Post: 2007-06-28, 06:17 PM
  4. Replies: 15
    Last Post: 2006-11-23, 02:47 AM
  5. Replies: 8
    Last Post: 2006-05-01, 06:39 PM
