I am looking for the procedure to have the time/Date print in the margin of the drawing when plotted in the same fashion as Autocad 14. This in Autocad 2000. You can respond back to terrypaul1@earthlink.net.
terrypaul... scroll down to the bottom of this page and check out the 'similar threads' feature at the bottom, automatically shows links to plotstamp/rtext, etc which should show you a solution.Originally Posted by terrypaul1
good luck.
Melanie Stone
@MistresDorkness
Technical Editornot all those who wander are lost
I think the command you are looking for is "plotstamp". In R2000 I think it is still located in the plotting dialog box with a little check box next to it. If you type "-plotstamp" it will let you enter everything at the command line.Originally Posted by terrypaul1
