Results 1 to 9 of 9
Thread: Can a floor plan become a level?
    NavisWorks Moderator david.kingham's Avatar
    2004-07
    Fort Collins, CO
    1,329
    Default Can a floor plan become a level?
    A coworker started this project when I was out of town and now it's a bit jacked up. My first floor and second floor plans seem to be setup as just floor plans, not levels. Problem is all the walls are constrained to the first floor plan but I have no First Floor level in my elevations/sections. Is there anyway to get levels in or do I have create new levels and reconstrain everything?
    Thanks
    I could stop if I wanted to cosmickingpin's Avatar
    2004-05
    North of the 49th
    476
    Default Re: Can a floor plan become a level?
    if walls are 'constrained by a "first floor level" then there is a first floor level. Create a new section or evelations and you should see it. If the project is in worksets he might have the level on a invisiable workset so turn on all owrksets in your new view. Unless he created the plans as horizontal section-detail views, in which case yes you will need to copy paste all your drafting elements into new plan views. so if you go "view-new-floor plan" the 'first floor' does not show up as an option? is that correct?
    Quote Originally Posted by david.kingham
    Thanks
    2004-07
    Fort Collins, CO
    1,329
    It does appear if i go to view>new floor plan so something is funky, maybe the levels are way off in the middle of nowhere hmm
    I could stop if I wanted to Tom Dorner's Avatar
    2003-11
    Phoenix, AZ
    371
    I also had a co-worker who got themselves into this same situation.
    I have been using Revit for two years now and I was unable to find any levels in the project, yet the walls were constrained to them.
    As far as I can figure, she deleted all the elevations and somehow levels got deleted as well. No scope boxes or worksets were present in the project, so I finally gave up trying to figure it out.
    We are seeing more of this kind of stuff happen in our office as the second and third wave Revit users get into projects and find all sorts of ways to mess things.
    Tom
    All AUGI, all the time J. Grouchy's Avatar
    2003-12
    Quhl Whirled
    896
    you sure it wasn't just renamed without updating the view names? (see below)
    2004-07
    Fort Collins, CO
    1,329
    Nope, I have no level at 100' or 113'-4" I tried deleting the floor plans and create a new level but it says the name entered is allready in use...i think I'll go cry now lol
    2004-05
    North of the 49th
    476
    in one ofyour elevations turn off your crop region, then zoom all then select everything on the screen, filter for levels only, then you can see where the heck your floor 1 is.
    2002-02
    St. Louis, MO
    4,695
    Or make a new elevation with no crop region - it has to show up then.
    2004-07
    Fort Collins, CO
    1,329
    Thank you guys that did it, very odd though, i was moving the crop region 1000's of feet and they never showed up, turn it off and they were only about 100' away from the building :shrug: who knows
  1. Change Associated Level of Floor Plan
    By m_cahoon14336 in forum Revit Architecture - General
    Last Post: 2015-06-12, 08:58 AM
  2. 2015: 1st level objects greyed out and visible on 2nd level floor plan
    By booyahhhnia342307 in forum Revit Architecture - General
    Last Post: 2015-06-11, 03:14 PM
  3. Ability to change the Associated Level of a Floor Plan after it has been created
    Last Post: 2013-06-07, 11:00 PM
  4. Varying Floor Level Plan View
    By artitech in forum Revit Architecture - General
    Last Post: 2005-07-02, 12:18 PM
  5. 2x2 ceilings are visible on floor plan level?
    Last Post: 2004-08-20, 01:22 PM
