Thread: Error Code 1602 & SP1
    Member awatkins's Avatar
    Baltimore
    13
    Angry Error Code 1602 & SP1
    A few folks in our office using ADT 2005 are having the problem of lockup or dramatic slowdown when using the Layer Properties dropdown. It was installed using a network install. After getting the old Error Code 1602 when installing SP1, we got around the network access problems and the Service Pack installed OK.
    However, after installing the SP, the problem persists.
    Any help?
    Time Lord Steve_Bennett's Avatar
    far, far, far away...
    4,730
    Default Re: Error Code 1602 & SP1
    This isn't nessecarily related to the SP. It's more likely that you hsve an over abundance of layer filters built up from legacy drawings. The lisp routine at the end of the thread for Layer Manager & Layer drop down are slow to open in the AutoCAD FAQ Forum should solve your issues.
    Steve Bennett |BIM Manager
    Taylor Design | Adventures in BIM
    Baltimore
    13
    Deleting the Layer Filters did the trick. Also, there were a large number of Registered Apps attached to the file. After purging those out, the files are working fine.
    Thanks for your help.
  1. Replies: 1
    Last Post: 2012-11-12, 11:12 PM
  2. error code in 3D Max 2010
    By pennygreg in forum 3ds Max - General
    Last Post: 2010-05-10, 10:07 PM
  3. error code bypass?
    By andreasen_michael_jon in forum VBA/COM Interop
    Last Post: 2008-01-10, 08:35 PM
  4. error in my code
    By d_m_hopper in forum AutoLISP
    Last Post: 2007-10-08, 04:30 PM
  5. ERROR CODE
    By LABELED1US in forum AutoCAD Map 3D - General
    Last Post: 2005-03-19, 03:57 PM
