Thread: SketchUp Plugins
    AUGI Addict Scott Hopkins's Avatar
    2003-05
    Santa Barbara, CA
    1,197
    Default
    This was news to me - SketchUp now has a Plug-in available for both ArchiCAD and ADT. Still haven’t forked over the money to buy SketchUp, but if they come out with a Plug-in for Revit I may be convinced. See article below,
    The SketchUp Plug-in for ADT
    One of the critical shortcomings in current building modeling solutions is their lack of support for conceptual design tasks such as programming, space planning, conceptual sketching, and massing, as I discussed in my recent A-E-C Automation Newsletter article. One step towards a solution to this problem has come with a new SketchUp plug-in for Autodesk Architectural Desktop (ADT), which was unveiled at Autodesk University by @Last Software. SketchUp is an easy, intuitive, and fun to use application for 3D design exploration, which has continued to gain in popularity in the architectural design community since its release in Fall 2000. (See my previous articles on SketchUp in Cadence AEC Tech News #102 and #80.) The availability of this plug-in should be welcome news to those using ADT for building modeling-the 3D design concepts they develop using SketchUp can be intelligently imported as building objects into ADT, giving them a head start on design development.
    The plug-in allows SketchUp data to be translated into ADT in different ways, depending upon the configuration and complexity of the SketchUp geometry. The simplest mode is automatic, in which all vertical surfaces become walls, all horizontal surfaces become slabs, and sloping surfaces become roof elements. Windows and doors also translate directly into ADT objects. If the 3D model configuration doesn't allow for a good translation using this method, specific surfaces can be differentiated with materials and an exact method of translation based on material can be specified. For a complex model for which neither of these methods works well, another more roundabout method is available: it uses section slices from SketchUp to convert lines to walls or curtain walls in ADT. While the plug-in does not guarantee a perfectly seamless and flawless translation for each model, it works well enough to save the time and tedium involved in developing the ADT model from scratch. More importantly, it is a great example of integrating diverse applications and workflows into a more coordinated design process.
    http://sketchup.com/plugins/
    I could stop if I wanted to Kroke's Avatar
    2003-04
    Redmond, OR
    446
    Default Re: SketchUp Plugins
    Ironic, I just ran into that on their site last night. Thinking "Cool, it's free! Oh wait, I dont use Ottocad anymore..." Oh well
    I could stop if I wanted to Cathy Hadley's Avatar
    2003-05
    San Diego
    222
    I talked to them some at AU, where they introduced this ADT plug-in. I was telling them how something similar would be really great for Revit.
    His answer was ... something to the effect of... know any Revit Programmers who'd be interested on working on it with us?
    He wasn't too encouraging ... but maybe its just a matter of numbers...
    CZH
    2003-05
    5,153
    I'd buy SketchUp immediately if they had a Revit plug-in.
    The file transfers seems to be the only stumbling block to using this great program.
  1. Revit Plugins and Extensions?
    By Tyveka in forum Revit Architecture - General
    Last Post: 2011-10-13, 09:28 PM
  2. 3ds Max Design 2011 Plugins
    By stephen.scott in forum 3ds Max - General
    Last Post: 2011-02-03, 07:56 PM
  3. Plugins for 2010
    By gugg in forum AutoCAD General
    Last Post: 2010-01-05, 11:04 PM
  4. COM DBX Extender Plugins
    By janne.salasmaa in forum NavisWorks - General
    Last Post: 2008-05-13, 11:11 AM
  5. Maxwell Render Plugins
    By Scott Hopkins in forum Revit - Rendering
    Last Post: 2005-03-28, 09:16 PM
