If you turn on your right click menu options so that a menu appears when an opject is selected there are a lot of convenient commands relevant to the object selected that are difficult to find otherwise.
For example, using LDT 2005, if you select a label and right click, there is an option to make the label style current, edit the label's properties, edit the labels style. Also true about contour objects, etc.
