Results 1 to 6 of 6
Thread: Background Mask Model or Paper Space Unstable
    2001-11
    236
    Question Background Mask Model or Paper Space Unstable
    I have done a search on the forums, read quite a handful of issues on background masking, but could not find my issue. I am using AutoCAD 2005.
    After creating a text with MText, and setting the background, I add a leader to what I am pointing to. When I regen, the masking disappears. However, when I pick the text, it shows the masking (or when I move the text). When I regen again, the text may or may not shows the masking. It is not consistent – this is very frustrating. I have used draw order to override or set the color level still not solved. Bye the way I am using an XRef to be blocked out. I tried with ordinary block, same problem.
    Any solution to this dilemma?
    I could stop if I wanted to scwegner's Avatar
    2004-12
    Minneapolis, MN
    449
    Default Re: Background Mask Model or Paper Space Unstable
    From my experience, it seems the problem happens when you edit something behind the mask and it's brought to the front. I find that quickly toggling TFRAMES (set to F4 for me) generally fixes the problem but I'm on an older version so...
    Member afortier's Avatar
    2005-01
    Middle of the Sunshine State
    40
    this isn't a real fixer for the problem, but i've had that same thing happen- wot i ended up doing was ereasing the text all together and started over or copy one that does work.
    I could stop if I wanted to JASONM30395's Avatar
    2002-04
    Halifax NS Canada
    397
    make sure your text is in front of everything in the draworder.
    Loyalty above all else except honor
    For my honor is my life!
    2005-01
    40
    Quote Originally Posted by jmelanson
    i found that that doesn't make a difference doing draw order w/ the background mask- but i could be wrong...that has happened @ least once b/4
    13,656
    Hi
    Apologies if the below is teaching you to suck eggs...
    _.TextToFront command (AutoCAD 2005 or above) is a very easy way of achieving this.
    Have a good one, Mike
  1. Replies: 2
    Last Post: 2014-02-18, 01:25 AM
  2. background color in paper space
    By rchampaia in forum AutoCAD General
    Last Post: 2014-01-23, 04:10 PM
  3. 2011: Paper Space Background Color
    By chris4455 in forum AMEP General
    Last Post: 2010-10-22, 08:06 PM
  4. What background do you use in paper space?
    By Steve Johnson in forum AutoCAD General
    Last Post: 2007-11-21, 03:04 PM
  5. Replies: 3
    Last Post: 2006-10-24, 07:05 PM
