is it just me or is this a major bug
try this simple excercise, create a simple plan 2 stories (even a square would do) now create a floor in the 1st floor larger than the actual walls and then create a plan region on the second floor somewhere
set the cut height in the plan region to anything other than the corresponding floors cut height, you'll notice that once done the floor from the first floor shows up in the second floor
the glitch is more apparent if you had 3 or 4 floors, if you placed a plan region in the 4th floor ALL floors from lower levels show up
whats up with that?
by the way i do have the latest build
