Results 1 to 6 of 6
Thread: Crashes after Upgrade.
    I could stop if I wanted to Paul Monsef's Avatar
    2003-09
    Everett, WA
    351
    Default
    This is kinda weird..
    I've been working on these stair railings, I noticed after i upgraded to 6.0.xxxx, one railing did not have it's top rail extended anymore... now whenever i edit the stair to change this... Revit crashes.
    Any thoughts? do i need to send this to Support?
    2003-09
    Everett, WA
    351
    Default Re: Crashes after Upgrade.
    alright... It crashes anytime i edit a railing style. (whether or not the style is in use) AND when i add railing styles by "transfering project standards".
    AUGI Addict aggockel50321's Avatar
    2003-05
    Waterville, Maine
    1,748
    Workgroups enabled?
    They seem to be the most prevelant cause of crashes discussed to date in 6.0.
    What type of crash?? No warning directly out, or "you need to save & get out" from Revit, or a "Your dead, do you wish to send a note along to Bill Gates about this problem?"
    2003-09
    Everett, WA
    351
    Yes, workgroups are enabled... The central file is offsite (connected through a VPN)
    I do get the option to save, so that's nice.. I can't even change the Trim/Weld option without it crashing.
    2003-09
    Everett, WA
    351
    ugh,, I just created a new sheet and tryed to add a view and it crashed (with the save option)...............
    Worksets - it is generally recommended that clients making use of worksets in 6.0 download and utilize tis latest build.
    2003-05
    Waterville, Maine
    1,748
    Take a look at this thread.http://www.zoogdesign.com/forums/php...pic.php?t=2328
    Steve Stafford had some good ideas that bailed me out.
  1. Revit 2013 upgrade yet? - softaware stability, crashes & bugs
    By andrewharle in forum Revit Architecture - General
    Last Post: 2013-01-08, 09:10 AM
  2. Replies: 0
    Last Post: 2010-04-01, 03:21 PM
  3. ADT CRASHES
    By Chuckyd67 in forum ACA General
    Last Post: 2006-11-07, 06:17 PM
  4. Upgrade the Upgrade Utility
    By ctc in forum Revit Architecture - Wish List
    Last Post: 2006-09-26, 01:58 PM
  5. upgrade to 8.1 crashes
    By Chirag Mistry in forum Revit Architecture - General
    Last Post: 2005-09-28, 03:44 PM
