Results 1 to 10 of 14
Thread: Help Changing text style in blocks
    Member MZerby's Avatar
    2004-11
    22
    Default Help Changing text style in blocks
    Hello again,
    I'm trying to update old drawings and details to our new standards. I was trying to find a way to change all the test and mtext from our old text styles to our new text styles. I have a lisp that will change all the text and mtext that is not in a block. I'm stuck on the one for the text that is embedded in a block though. Below is what I've been working on. I've been stuck for a while now and was hoping someone may be able to see my problem. I'm still pretty new to this.
    Mike
    (defun chblk ()
      (setq objs (ssget "x" '((0 . "INSERT")))
    	in   0
      (repeat (sslength objs)
        (setq ent (ssname objs in)
    	  lst (entget ent)
        (if	(= (cdr (assoc 0 lst)) "INSERT")
          (progn
    	(setq ename (cdr (assoc -1 lst)))
    	(while (setq ename (entnext ename))
    	  (if (or (= (cdr (assoc 0 (entget ename))) "TEXT")
    		  (= (cdr (assoc 0 (entget ename))) "MTEXT")
    	      )				;or
    	    (progn
    	      (setq lst	 (entget ename)
    		    name (cdr (assoc 7 lst))
    	      (cond
    		((null name))
    		((= name "Std Text")
    		 (setq lst (subst (cons 7 "FORMAT1") (assoc 7 lst) lst))
    		 (entmod lst)
    		 (entupd (cdr (assoc -1 lst)))
    		 (setq n (+ 1 n))
    		((= name "SS")
    		 (entmod lst)
    		 (setq n (+ 1 n))
    		((= name "S")
    		 (entmod lst)
    		 (setq n (+ 1 n))
    		((= name "STADARD")
    		 (entmod lst)
    		 (setq n (+ 1 n))
    		((= name "D")
    		 (setq lst (subst (cons 7 "FORMAT2") (assoc 7 lst) lst))
    		 (entmod lst)
    		 (setq n (+ 1 n))
    		((= name "T")
    		 (entmod lst)
    		 (setq n (+ 1 n))
    	      )	;cond
    	)	; if
          )		; while
          (setq in (1+ in))
      (alert (strcat (itoa n) " Items Changed "))
    AUGI Addict fixo's Avatar
    2005-05
    Pietari, Venäjä
    1,269
    Default Re: Help Changing text style in blocks
    Try this one
    Thank you
    Fatty
    2004-11
    22
    Thanks for the code sample. I downloaded it and tried it. Your right about my spelling of STANDARD being wrong. After I corrected my spelling it gave me the error (ActiveX Server returned an error: Parameter not optional) Seemed to be at (vla-put-stylename i new_stl). I've never tried using visual lisp yet, but I think it's because the drawing does have other Text styles in it that I want to let alone and if it's one of those I get a nil for the new_stl variable.
    Does this code change all text and mtext styles or does it just change attribute text styles?
    Mike
    2005-05
    Pietari, Venäjä
    1,269
    This is for attribute text style only so you asked
    Tomorrow I'll can write for the text or MText and for attributes
    Thank you
    Fatty
    2005-05
    Pietari, Venäjä
    1,269
    Hi Mike!
    Sorry no time to test this please test yourself
    Thank you
    Fatty
    2011-11
    I am new to lisp, as in I just started researching them at the beginning of this week. I have a drawing with about 100 blocks and I need to change the text style in each of these blocks from STANDARD to SECURITY.
    If I am reading the post right your lisp will do that, am I correct in that?
    If so, how do I load it? I realize this is a day question to most of you, however this is in fact my day one and I have no formal training on lisp.
    Thank you for you help.
    Nathan
    Past Vice President / AUGI Volunteer peter's Avatar
    2000-09
    Honolulu HI
    1,104
    I always like it when the code sample is posted.
    Here is something I cooked for this response.
    syntax:
    (changestyle <oldtextstylename> <newtextstylename>)
    P-
    (defun ChangeStyle (strStyle1 strStyle2 / entItem objBlock objDocument objItem )
     (vl-load-com)
     (setq objDocument (vla-get-activedocument (vlax-get-acad-object)))
     (if (and (tblobjname "style" strStyle1)
              (tblobjname "style" strStyle2)
      (vlax-for objBlock (vla-get-blocks objDocument)
       (if (> (vla-get-count objBlock) 0)
        (progn
         (setq objItem (vla-item objBlock 0)
               entItem (vlax-vla-object->ename objItem)
         (while entItem
          (if (and (vlax-property-available-p (setq objItem (vlax-ename->vla-object entItem)) "StyleName")
                   (= (strcase (vla-get-stylename objItem)) (strcase strStyle1))
           (vla-put-stylename objItem strStyle2)
          (setq entItem (entnext entItem))
      (princ "\nError check if styles exist: ")
     (vla-regen objDocument 0)
    AutomateCAD
    2011-12
    11
    I know this is an old thread but I have a similar problem only the blocks are not created and/or recognized bij autocad
    so block editor won´t work but I do have attributes (?) in the wrong tekst style. Filtering won't work either.
    Does anyone have a lisp to change the tekst style for all tekst or maybe for all attributes in one block?
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,655
    Quote Originally Posted by sva840811 View Post
    I know this is an old thread but I have a similar problem only the blocks are not created and/or recognized by AutoCAD so block editor won´t work but I do have attributes (?) in the wrong tekst style. Filtering won't work either.
    Can you attach a small drawing with blocks not created or recognized by AutoCAD with attributes? Only thing I can think of is a label from an AutoCAD verticle like Civil 3D.
    2011-12
    11
    I have no idea what program was used but no not recognized and yes actual attributes, I can change the text style for every single attribute but I can't use block editor or the lisps mentioned here, so I have to do it one by one
  1. Replies: 1
    Last Post: 2014-08-08, 05:20 PM
  2. Isolate Selected Text Style or Dim Style
    Last Post: 2013-01-20, 05:10 AM
  3. changing existing text to new style with LiSP
    By gallows214585 in forum AutoLISP
    Last Post: 2010-03-04, 08:59 PM
  4. Changing font without changing Text Style.
    By zoomharis in forum AutoCAD General
    Last Post: 2006-03-22, 05:51 PM
  5. Changing text height and style in AutoLISP
    By ahipkin60511 in forum AutoLISP
    Last Post: 2004-07-19, 08:13 AM
