Results 1 to 9 of 9
Thread: Plot White Text on a Black background
    All AUGI, all the time Katika's Avatar
    2004-07
    Perth Australia
    736
    Question Plot White Text on a Black background
    I have a logo that I'm trying to make up, and it's white text on black background (plus a shape around it)
    Does anyone know of a way to set it up so it prints white on black, or am I stuck with trying to trace around it?
    Only thing I found with a search was textfill, but this will then remove fills from all text rather than just the logo portion.
    Kathy Taylor
    Senior Structural Draftsperson & Proprietor
    TaylorCAD
    www.taylorcad.com.au
    I don't suffer from insanity - I enjoy it!
    Revit User Phase 3, 4, 5, 4, 3, 5, 4.....
    13,621
    Default Re: Plot White Text on a Black background
    Hi
    Check out the following Technical Document on the Autodesk web site under the Knowledge Base section -
    ID: TS71835 - Plot white lines on dark background
    Have a good one, Mike
    100 Club noozybkk's Avatar
    2005-05
    Bangkok, Thailand - (Currently working in Dubai)
    141
    Our company logo is also white text on a coloured background. What I did was use Express Tools to explode a bold outline font and then hatch around the letter outlines with solid hatching.
    The letters appear white (well actually clear - it's the paper thats white)
    2004-07
    Perth Australia
    736
    Thanks guys, unfortunately I can't seem to set the screening up so that the solid hatch gets blanked under the font I want to use (it will work for a different font) so I guess it's exploding and hatching.
    Kathy Taylor
    TaylorCAD
    13,621
    Hi
    Can you please post an example drawing file, plus the Plot Style Table you are using.
    Why? - With the simple testing I carried out here, I was able to achieve the results I believe you are after.
    2004-07
    Perth Australia
    736
    I already did the hatched version, I think the problem was that originally I was using Romant. I believe it was the difference between using a ttf and an shx.
    Kathy Taylor
    TaylorCAD
    13,621
    Quote Originally Posted by taylorcad
    Hi
    Both types of font (SHX & TTF) appeared to work for me... please find attached the very simple test I carried.
    2004-07
    Perth Australia
    736
    1 members found this post helpful.
    Thumbs up Re: Plot White Text on a Black background
    Quote Originally Posted by Mike.Perry
    Hi
    Thanks for taking the time to look at it Mike.
    It works for me now too....a little confused why it wouldn't at the time
    Something must have really whacked out my settings for a while there because some of my alias keystrokes redifined themselves back to defaults.
    Kathy Taylor
    TaylorCAD
    2004-10
    22
    Smile Re: Plot White Text on a Black background
    I often have to do white text on a coloured or black background.
    What I do is select the colour of the text to be colour 255 (not quite white, but doesn't really notice).
    Do your text, (use a TTF, they have more 'body'), put a rectangle or whatever around it ('Enclose text with object' in Express tools is a handy way to do it), hatch the rectangle in solid white, then select the text and use 'Bring to front' .
    Do a regen and it should all look as you want it to.
    Hope this helps
    Pat
    Last edited by patricia.ellistone; 2005-12-16 at 11:03 AM. Reason: thought of something to add.
  1. Custom background color other than white or black.
    Last Post: 2012-11-19, 10:35 PM
  2. White text on black background
    By jhanby in forum Revit Architecture - General
    Last Post: 2007-08-09, 07:55 PM
  3. White text, black background
    By jmctamney in forum AutoCAD General
    Last Post: 2006-10-30, 02:01 PM
  4. Plot Preview Background is Black not White
    By cadmecheng in forum AutoCAD Plotting
    Last Post: 2006-01-24, 09:55 PM
