Results 1 to 10 of 18
Thread: RCP content in revit how?
    2001-07
    481
    Default RCP content in revit how?
    How do I place rcp content in my revit model?
    I know that revit comes with some content but not a clue how to place it in the model or how to add new content from rcp.
    thanks
    AUGI Addict iru69's Avatar
    2004-10
    usa
    1,591
    Default Re: RCP content in revit how?
    I believe it's actually "RPC" content which may be why you're having a hard time finding info.
    If you search Revit's help file for RPC, you'll get step by step instructions for loading content. But, in a nutshell, you load it just like any other families. Try looking under Entourage in your Families folder. When you first place an RPC family, It's not much to look at - but as soon as you render it, it looks pretty good.
    Check out archvision for more info on getting additional RPC content.
    2001-07
    481
    Thanks for your answer but I noticed that there is only a few families in the entourage library? Is that means that I can not use my library of rcp content? can I use only those four families? can create mor families with different content?
    2004-10
    usa
    1,591
    Quote Originally Posted by Wagurto
    You have your own library of RPC content?
    Well, if it's compatible with Revit (not all RPC content is), you can create a new RPC family (there should be a RPC family template), or copy an existing one. Edit the Family Types of the RPC family and you can then edit the RPC properties which will let you browse to the corresponding RPC file.
    Revit Technical Specialist - Autodesk Scott Davis's Avatar
    2003-04
    Chino, CA
    4,743
    Put all of your RPC content in the same folder as the stock Revit content, in the Rendering folder. If you want a new RPC person, first load a 'stock' Revit RPC, such as RPC Male.RFA. This one RPC family, like all other Revit content, has multiple 'types'. Stock comes with Dwayne, Alex, and LeRon for males. Go to the Properties of the Revit family, and just as with any other Revit family, hit the Duplicate button to make a new Type. Name it whatever you'd like. Then Click the Edit button, browse to your new RPC 'character', and load the RPC. You have just assigned a new RPC character to the Revit family for that project.
    Do the same for any other RPC you might have in your own library.
    Scott D Davis
    AEC Technical Specialist
    Autodesk, Inc.
    http://about.me/scottddavis
    2001-07
    481
    Once again, professor Scott give a lesson.
    Thanks you are the man.
    100 Club Gene Herring's Avatar
    2005-06
    103
    Question Re: RCP content in revit how?
    Scott I am following your instructions and navigate to the right spot with no trouble. When i select browse and select the additional content to load, Revit crashes every time! any Ideas?
    100 Club D_Driver's Avatar
    2003-11
    Ashland Oregon
    194
    I have seen this before, they fixed this a bit in 8...what version are you using?
    1st - yes you can open one of the existing entourage do a saveas, or 2 - there is a template for these
    RPC Family.rft
    you have to use this rather than the entourage template to get the proper parameters.
    - but always easier to start with existing content - and if you are doing a person, then by all means, but if you are doing an rpc car or tree, then you need to start with the template.
    have a line drawing handy because the template does not have any linework in it.
    secondly as Scott said
    "Put all of your RPC content in the same folder as the stock Revit content, in the Rendering folder"
    your rpc file MUST exist in one of the paths specified in the
    Settings>Options>Rendering:Additional rendering material directories.
    by default the supplied RPC stuff is in
    C:\Documents and Settings\All Users\Application Data\Autodesk\Revit Building 8\Rendering\RPCPeople
    so copying your rpc to this dir will do the trick, but will cause some grief/duplication with the RPC download engine - so you can add a directory pointing to where your rpc stuff is.
    This is not intutive, because in the family you have to path each RPC piece anyway, but even if you point to a piece of RPC that is not pathed as per above, you will have problems later.
    I was doing several trees this way in v7 and would crash quite a bit.
    I just quickly went through in 8 and did not crash, but was not really trying to push it.
    2005-06
    103
    Thanks for the info driver. I am using 8.0, I will give your suggestions a try.
    2005-06
    103
    Cool Re: RCP content in revit how?
    Hey Driver, asking for your help again. I am still getting instant crashes each time I attempt to "edit" one of the stock RPC object or load a new from my library of RPC content. It is weird, the moment I Anyone else out there having problems besides us?
    Another side question, is the stock rpc content with 8.0 the 2.5 version that will not animate?
  1. Revit MEP content downloads
    By aaronhacker92 in forum Revit MEP - General
    Last Post: 2010-06-15, 03:54 PM
  2. Revit 64 Content
    By gwnelson in forum Revit Architecture - General
    Last Post: 2008-10-02, 10:30 PM
  3. RPC Content from Revit To Viz
    By cosmickingpin in forum Revit - Rendering
    Last Post: 2006-01-26, 02:10 PM
  4. We NEED CONTENT for the Revit Exchange!
    By Scott Davis in forum Revit Architecture - General
    Last Post: 2004-11-10, 10:19 AM
