Thread: Curtain Mullion Profiles & Linework Visibility...
    2004-03
    Columbus, OH
    93
    Default Curtain Mullion Profiles & Linework Visibility...
    I am trying to develop a custom mullion profile for tilt-up concrete panel construction. I will be using a combination of curtain walls with embedded wall families as curtain panels. The curtain wall approach will make it easier to manage the "individual" panels, especially for curvilinear segments.
    For appearance sake, I don't want the exposed faces of the curtain mullion profile displaying. I am seeking a clean joint appearance. In the curtain mullion profile template, there is an <Invisible Lines> category from the line type selector window. I mapped this property to the exposed face linework.
    I saved the profile family and loaded it into a project and created a new mullion type and mapped the new curtain mullion profile to it.
    Result:
    The exposed faces are still visible in the project.
    Other project conditions to be addressed:
    In this project, there will be a combination of curtain wall types where mullions will need to be visible and invisible. Therefore, using visibility/graphic settings will not work in this context. This type of construction is the primary shell envelope.
    Workarounds attempted:
    A) Experimented with linework Visibility turned off for course in profile family. Same results above.
    B) Fact: Mullion profiles require a closed loop.
    C) Split Walls With Gap. Unfortunately, this splits the curtain wall and not the embedded wall. A tab selection set process to access nested elements would be beneficial here.
    Questions:
    1) What is the purpose of <Invisible Lines> in the mullion family?
    2) Is there a way to create sub-categories in the mullion family? I don't see a way natively.
    3) What other suggestions can be explored?
    Thanks in advance for your help!
    John Herridge, AIA
    2005-10
    29
    Exclamation Re: Curtain Mullion Profiles & Linework Visibility...
    have you gotten any response from anyone?.
    this is the same question i wanted to ask reviteers out there.
    somebody answer please!.
    2003-12
    87
    Default Re: Curtain Mullion Profiles & Linework Visibility...
    Attached is a "mullion" modeling the silicon joint.
    Views as a negative detail, and is the usual way we construct using tilt up concrete.
    Tried the visibility settings, and can't turn the mullion off in the family either.
    I suspect the only time you will want to turn it off is if you are scheduling the panels, in which case you can probably turn all the mullions off using Visibility Graphics anyways.
    Hope this helps - C
  1. Embedded Details Flipping within Curtain Wall Mullion Profiles
    By etboards17 in forum Revit Architecture - General
    Last Post: 2012-10-30, 10:39 AM
  2. Editing curtain wall mullion profiles
    By chandel in forum Revit Architecture - General
    Last Post: 2011-02-15, 08:54 PM
  3. Transfer Project Standards - mullion profiles
    By ws in forum Revit Architecture - General
    Last Post: 2007-11-07, 09:13 AM
  4. curtain wall mullion - cuting curtain panels
    By janunson in forum Revit Architecture - Families
    Last Post: 2006-11-02, 08:24 PM
  5. Revit 7 Mullion Profiles
    By jerry_toy in forum Revit Architecture - Families
    Last Post: 2004-12-22, 03:33 PM
