Thread: Excel paste link - Failed to create object. Make sure the object is entered...
    2002-05
    13
    Exclamation Excel paste link - Failed to create object. Make sure the object is entered...
    needing some help on this. I am trying to PASTE SPECIAL an excel table link into an AutoCAD 2005 drawing, but every time I go to select the insertion point I get the following error message:
    Failed to create object. Make sure the object is entered in the system registry.
    Does anyone know what this means?
    cheers
    2000-01
    Seattle WA USA
    5,859
    Default Re: Excel paste link - Failed to create object. Make sure the object is entered...
    I would perform a Add/Remove Programs Registry Repair install on both MS Office and AutoCAD.
    13,656
    Hi
    Just to go with what Robert suggested above, check out the following Technical Document on the Autodesk web site under the Knowledge Base section -
    ID: TS43271 - Unable to insert OLE object
    Have a good one, Mike
  1. Failed to create CommCntrClientSink object
    By behnam_osk in forum Productstream - General
    Last Post: 2009-12-14, 07:28 AM
  2. Failed to create commcntrclient sink object - when opening AutoCAD LT 2007
    By dmcmillan.50355 in forum AutoCAD LT - General
    Last Post: 2006-10-05, 01:46 PM
  3. Insert Excel into AutoCAD - Failed to create object...
    By joey.tadeja in forum AutoCAD General
    Last Post: 2005-12-15, 07:18 PM
  4. Failed to Create object
    By timd in forum AutoCAD General
    Last Post: 2004-12-07, 08:36 PM
  5. Failed to create Commcntrclientsink object
    By GreyHippo in forum AutoCAD General
    Last Post: 2004-12-02, 02:39 PM
