Thread: Dual Monitors
    All AUGI, all the time gwnelson's Avatar
    2003-04
    Westchester County, NY, USA
    612
    Question Dual Monitors
    Since I got a new monitor with my new computer I decided to try a dual setup using my old monitor, too. It's a whole new world of expanded vision & everything works great, except: I can't keep the Project Browser fixed in the secondary monitor. Every time I switch projects or families the browser flips back to the primary monitor. Any known way to lock or does this qualify as a wish list item? BTW - given the current cost of monitors, this is the only way to work.
    All AUGI, all the time Les Therrien's Avatar
    2003-05
    Tecumseh, Canada
    623
    Default Re: Dual Monitors
    That's the way it'll be.
    Revit currently doesn't suuport dual monitors the way we would like them to.
    If you insist on that setup, you will have to re-set it everytime!
    I just have Revit set up on 1 monitor and everything else on the other.
    All AUGI, all the time mlgatzke's Avatar
    2003-05
    Ankeny, Iowa, USA
    761
    I don't know if Les is more, but Les is right. Revit doesn't support multiple monitors, currently. I would only suggest that you make sure that you are running Revit on your Primary monitor, because Revit has a tendency to run rather oddly on a secondary monitor (i.e. drop-downs that don't work, etc.). Just move all of your other "stuff" to the secondary monitor.
  1. 2013: Dual Monitors
    By etaveras395020 in forum Revit - Tutorials
    Last Post: 2013-10-08, 08:11 PM
  2. Dual Monitors
    By fyarch135738 in forum Revit - Hardware & Operating Systems
    Last Post: 2009-04-22, 10:22 PM
  3. Dual Monitors
    By charliep in forum Revit Architecture - General
    Last Post: 2008-02-28, 05:18 PM
  4. Dual Monitors
    By falls-c in forum Hardware
    Last Post: 2005-08-24, 10:33 PM
  5. dual monitors
    By cooley28 in forum AutoCAD General
    Last Post: 2005-02-14, 12:23 PM
