Thread: Added Parameters to the Titleblock Info
    2003-09
    1,907
    Default Added Parameters to the Titleblock Info
    Many questions on how to add a "Number of sheets" Line on the titleblock prompted this tutorial. This is not an automated number, but it is a single source to update all sheets.
    Enjoy. IF you find text errors, or have additional questions, post or PM me.
    AUGI Addict blads's Avatar
    2015-10
    out cycling somewhere... I wish...
    2,285
    Smile Re: Added Parameters to the Titleblock Info
    Quote Originally Posted by Skisouth
    thanks heaps - great tutorial
    Cheers @blads
    Mac Geek | Building Design Suite 2020 | Semi-Retired Building Designer / CAD-BIM Trainer | Autodesk Certified Professional
    2011-04
    13
    Default Re: Added Parameters to the Titleblock Info
    This works great, Thanks!
    Still over 7 years later there is no method that you can:
    1. Show the "Sheet Number: _____ of _____" ?
    2. Can you add the Number in the schedule?
    Example in bold:
    Sheet Schedule
    A-1 | (sheet name) | 1
    A-2 | (sheet name) | 2
    S-1 | (sheet name) | 3
    S-2 | (sheet name) | 4
    E-1 | (sheet name) | 5
    E-2 | (sheet name) | 6
  1. Added Revision Drawing List Parameters
    Last Post: 2014-02-21, 07:46 PM
  2. Project Issue Info on Titleblock from Revision Schedule
    By twollifur in forum Revit Architecture - General
    Last Post: 2010-07-21, 01:59 PM
  3. New Parameters in a Titleblock
    By tlagace in forum Revit Structure - General
    Last Post: 2006-08-21, 02:26 PM
  4. Trouble with titleblock info
    Last Post: 2006-01-04, 04:21 PM
  5. Family Category and Parameters can Additional ones be added
    By jarod.tulanowski in forum Revit Architecture - General
    Last Post: 2005-01-28, 05:59 PM
