Thread: Window Muntins
    2004-02
    6
    Default Window Muntins
    OK.. searching the forums and all I found for window muntins is an object family. Is this the easiest way to get window muntin in your windows?
    2003-05
    5,153
    Default Re: Window Muntins
    My search on keyword " muntin* " returned 55 topics.
    What exactly are you asking ? - how to nest a muntin family and display it by a parameter ? Search for the thread on " Anderson Windows" in the Families Forum, which, from memory , has a good explanation of this together with a family file posted.
    Bruce Gow.
    Karel*CAD. Application Specialist..
    Architect.
    Revitalize. Blog
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,440
    I usually build them in the family, start with the right base window type, then add the desired design. But if you are trying to create a "kit of parts" then you want to have them as a nested family that you specify various visibilitys. Someone on the forum, I think around the release of 7.0 created a window family with various grid patterns all in one window.
    Scott D. Brown, AIA
    BECK
    AUGI Addict Scott Hopkins's Avatar
    2003-05
    Santa Barbara, CA
    1,197
    I made some parametric muntins a while back. I posted instructions on how to use them.
    http://forums.augi.com/showthread.php?t=9344
    2004-02
    6
    Perfect, just wanted to make sure I wasn't doing it the wrong way.
    mc
  1. How to add muntins to window
    By buttonsrtoys in forum Revit Architecture - General
    Last Post: 2010-01-28, 01:31 PM
  2. window muntins - stretchable, 1x2 to 5x5
    By cole.152249 in forum Dynamic Blocks - Sharing
    Last Post: 2009-01-30, 04:06 PM
  3. Window muntins modify
    By Bill.Jensen in forum ACA General
    Last Post: 2006-07-19, 08:48 AM
  4. Question about arrays, groups and window muntins
    By zaklee in forum Revit Architecture - Families
    Last Post: 2006-06-06, 07:31 AM
  5. Looking for Window Family w/ Muntins & Trim
    By rgecy in forum Revit Architecture - General
    Last Post: 2003-09-10, 07:51 AM
