OK.. searching the forums and all I found for window muntins is an object family. Is this the easiest way to get window muntin in your windows?
My search on keyword " muntin* " returned 55 topics.
What exactly are you asking ? - how to nest a muntin family and display it by a parameter ? Search for the thread on " Anderson Windows" in the Families Forum, which, from memory , has a good explanation of this together with a family file posted.
I usually build them in the family, start with the right base window type, then add the desired design. But if you are trying to create a "kit of parts" then you want to have them as a nested family that you specify various visibilitys. Someone on the forum, I think around the release of 7.0 created a window family with various grid patterns all in one window.
Scott D. Brown, AIA
BECK
I made some parametric muntins a while back. I posted instructions on how to use them.
http://forums.augi.com/showthread.php?t=9344
Perfect, just wanted to make sure I wasn't doing it the wrong way.
mc
