Page 1 of 4 1234 LastLast
Results 1 to 10 of 36
Thread: Cutting through Sweeps
    AUGI Addict bowlingbrad's Avatar
    2003-11
    Chicago
    1,233
    Default Cutting through Sweeps
    I'm trying to place a scupper opening through a sweep. I've tried all of the different sweep types (hosted, within the wall definition). To no avail. I've tried the opening tool, a generic model and a window for the scupper. To no avail. Any suggestions?
    2003-04
    Chino, CA
    4,756
    Default Re: Cutting through Sweeps
    A "window" family that is nothing more than an opening should do the trick, but you've already tried?
    2003-11
    Chicago
    1,233
    Yep.
    I think I'm going to have to use a split region where I want the scupper and not touch both wall sweeps. That way I can put an opening in the wall and get the scupper to show in section. This really screws up my building. I have modified a good portion of the sweep returns. I'm going to loose all of the returns!!!
    2003-04
    Chino, CA
    4,756
    Your 'window' would need to cut all the way through the sweep, and it only cuts the center portion, right?
    2003-05
    Waltham, MA
    285
    Did you check the "Cuttable" box for the sweeps in the wall definition? This is a new 8.0 param we implemented just for this purpose.
    Post your model here if it still does not work.
    Tamas
    Aussie Revit Moderator Mr Spot's Avatar
    2004-05
    Brisbane
    1,115
    You also have to make sure your family for the window is upgraded to version 8.0. Which would involve editing the family, changing a value for a parameter and applying it, then change it back then reload back into the project.
    This will cause it to take on the new behaviour. That is to be able to cut sweeps. It works for us here as we have quite a few wall types with built in wall sweeps now.
    HTH.
    Chris Price
    Co-Founder/BIM Manager/Product Designer
    Xrev Pty Ltd
    Revit Rants BLOG
    2003-11
    Chicago
    1,233
    Here is a wall with a sweep that has an 'opening' cut into it. Not a window, not a door, just the simple opening tool.
    The sweep is cut, all right. But all I wanted was the opening. Not the entire sweep cut.
    2003-05
    Waltham, MA
    285
    Brad,
    Would you mind posting this little revit file here?
    Thanks,
    Tamas
    2003-11
    Chicago
    1,233
    Here's the little bugger.
    2003-05
    Waltham, MA
    285
    I am sorry Brad, but we do not consider these wall openings for modifying the sweep. (You could say this was an oversight.)
    One workaround is to use a frameless window.
    Tamas
  1. 2012: Cutting Voids in Masses, cutting windows and view range
    By edaviesc380864 in forum Revit - Student Support
    Last Post: 2013-05-15, 02:09 AM
  2. Cutting/Splitting Sweeps
    By mtlengel in forum Revit Architecture - General
    Last Post: 2008-09-04, 05:40 PM
  3. wall sweeps not always cutting joined walls
    By chris.macko125036 in forum Revit Architecture - General
    Last Post: 2008-04-24, 03:36 AM
  4. Cutting Sweeps?
    By Fishmonger in forum Revit Architecture - General
    Last Post: 2006-02-04, 03:45 PM
  5. doors/windows cutting sweeps above
    By cliff collins in forum Revit Architecture - General
    Last Post: 2004-12-08, 09:45 PM
