Thread: Changing default font
    2003-08
    Las Cruces, NM
    149
    Default
    Could someone please tell me how to change the default text font in revit?
    Thanks
    All AUGI, all the time Allen Lacy's Avatar
    2003-04
    Richmond, VA
    545
    Default Re: Changing default font
    Select the text note, then click on propeties. Then you can edit or create a new text style. You can choose from any Truetype font available (no .shx fonts in Revit).
    2001-12
    Irvine, CA
    7,567
    To completely set a font as the standard for an office you should create a template where all text, dimension styles etc. are defined and all annotation objects that are "outside" the template should be set and re-imported. If you don't then you run the risk of a rogue annotation object infiltrating your standards.
    Arial is what you get "out of the box", take the "low" road and you're already done . Take the "high" road and it will take some planning and effort to get everything changed to something else but once done...you're good to go till the next partner wants a different font.
    Maintain your templates and annotation families (and be consistent particularly when creating new ones) faithfully and you're good to go.
    2009-04
    85
    Hi,
    You can find somethig on this topic here:
    http://revitbeginners.blogspot.com/2...ing-fonts.html
    Hope this helps
  1. default font
    By cr_gixxer in forum Revit Architecture - General
    Last Post: 2007-03-21, 02:16 AM
  2. Changing font without changing Text Style.
    By zoomharis in forum AutoCAD General
    Last Post: 2006-03-22, 05:51 PM
  3. I wish there was a Default font feature
    By cadkiller in forum Revit Architecture - Wish List
    Last Post: 2005-02-14, 06:16 PM
  4. Changing Revit's Default Font
    By bmarler in forum Revit Architecture - General
    Last Post: 2005-01-27, 08:25 PM
  5. Replies: 5
    Last Post: 2005-01-04, 07:19 PM
