Results 1 to 10 of 12
Thread: Make CAD drawing look like a hand drawing
    2001-11
    200
    Default Make CAD drawing look like a hand drawing
    Hi
    Unusual query this and most probably in the wrong forum however here goes.
    I have been asked if I can make CAD drawings appear as thought they have been hand drawn.
    I am using 2000i although I do have part access to 2005.
    Has anyone got any ideas? Apologies if this is a daft question.
    Regards
    Neil
    AUGI Addict Maverick91's Avatar
    Grand Prairie, Texas, USA
    1,324
    Default Re: Make CAD drawing look like a hand drawing
    Quote Originally Posted by neilcheshire
    Hi
    Regards
    Neil
    We've used a program call Squiggle before. If you do a Goggle search I'm sure you can find it.
    All AUGI, all the time bbapties's Avatar
    2003-12
    Palm Harbor, FL
    537
    also take a look at this thread
    I could stop if I wanted to scwegner's Avatar
    2004-12
    Minneapolis, MN
    449
    Well, there are any number of fonts that are designed to look handmade floating around like arch.shx, architxt.shx, archs.shx, archstyl.shx, etc. For the drawing itself, there's a lisp called Roughen by Mark Middlebrook which I've attached that will take straightlines and make them a little crooked. Be careful with this though. You'll want to save a separate file for this because once you roughen something, there's no going back and editing a roughened drawing can be a pain.
    Member rebecca's Avatar
    2006-01
    8
    Quote Originally Posted by Maverick91
    I am researching using Squiggle, and I read in other posts that a plot file is used as the file that Squiggle processes. Is there a way to make a plot file directly from Revit (we only print pdf's), or do I have to export to AutoCad or Microstation fiirst, then create a plot file, and then import to Squiggle?
    I don't know AutoCad, so hopefully knowledge of it is not required to go from Revit to Squiggle.
    I could stop if I wanted to andy.manninen's Avatar
    2015-10
    @ _ork
    304
    Can you set a pen setting to vary a little? that would be the best solution, as it doesn't change any linework.
    I could stop if I wanted to Ammon's Avatar
    2005-06
    Salt Lake City, Utah
    423
    Quote Originally Posted by rebecca
    This is from the Squiggle Website. I don't work with Revit so I don't know if it has the capability of output to a HPGL or HPGL/2, dxf, or dwg file types, but if it does any of those, I presume it will work.
    Quote Originally Posted by squiggle website
    What Applications Does Squiggle Work With?
    Squiggle works great with AutoCAD, AutoCAD LT, AutoSketch, ALLPLAN, Cadkey, CorelCAD, Corel VisualCADD, CorelDraw, DataCAD, DesignCAD, Draphix CAD, Drawbase, DynaCADD, EasyCAD, MicroStation, TurboCAD, or any CAD, drawing, or graphics application that outputs HPGL or HPGL/2 files. DXF files or DWG files.
    2005-12
    Philippines
    10
    hi...
    you can do this trick in Architectural Desktop
    geri
    2005-08
    Albania
    423
    Hello sir
    I don't know if this reply it is just your answer that you required.I ask you
    have you used "Sketch" command?.or use "spline" command.
    2005-07
    2,356
    We use napkin sketch in ADT which works quite well - not sure if it is in vanilla cad though.
  1. How to make a new Drawing Template for ASD 2011
    By billbe466349 in forum AutoCAD Structural Detailing
    Last Post: 2012-11-20, 11:17 AM
  2. Make an open drawing visible in the drawing editor
    By victorbarrage528662 in forum AutoLISP
    Last Post: 2011-02-10, 01:15 AM
  3. Turn Revit into a hand sketch drawing
    By anthony.67953 in forum Revit Architecture - General
    Last Post: 2009-08-06, 05:18 AM
  4. make Xref drawing the master
    By kevranemail-augi in forum AutoCAD Wish List
    Last Post: 2005-05-20, 03:13 PM
  5. make Xref drawing the master?
    By kevranemail-augi in forum Facilities Management In Practice
