Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Make CAD drawing look like a hand drawing
  1. #11
    2004-06
    8
    0 Did you find this post helpful? Yes
    Default Re: Make CAD drawing look like a hand drawing
    The Architectural Desktop version has a plug in called "Napkin Sketch". I use it frequently to make the drawings look like sketches for presentation. I am not sure how or where to obtain this plugin outside of the ADT upgrade but something tells me if you look around you might be able to find it through AutoDesk. I will check my program to see if I can locate a brand.
  2. #12
    2005-05
    IL
    101
    Use M-Color......it has many effects that can give you that look plus it does other things for making great looking presentation drawings. It will apply the effect to objects based on what layer they're on in Autocad and it even works on text so it doesn't matter what font you have. Hope that helps you out, good luck.
    http://www.m-color.com
    http://www.m-color.com/m-color/gallery/default.html
    Last edited by Fillet Radius Zero; 2006-01-31 at 05:39 PM. Reason: additional information
    Mike Pollock
    Project Designer
    Farnsworth Group, Inc.
    **Infrastructure Design Suite 2014 **Navisworks **ArcMAP **Revit **
  1. How to make a new Drawing Template for ASD 2011
    By billbe466349 in forum AutoCAD Structural Detailing
    Last Post: 2012-11-20, 11:17 AM
  2. Make an open drawing visible in the drawing editor
    By victorbarrage528662 in forum AutoLISP
    Last Post: 2011-02-10, 01:15 AM
  3. Turn Revit into a hand sketch drawing
    By anthony.67953 in forum Revit Architecture - General
    Last Post: 2009-08-06, 05:18 AM
  4. make Xref drawing the master
    By kevranemail-augi in forum AutoCAD Wish List
    Last Post: 2005-05-20, 03:13 PM
  5. make Xref drawing the master?
    By kevranemail-augi in forum Facilities Management In Practice
