Results 1 to 7 of 7
Thread: In Place Family Circular Reference Error
    2005-05
    TX
    447
    Default In Place Family Circular Reference Error
    I am trying to create some rotated windwos as an in place family. The sketches work fine and it all looks good in 3D, but when I try to "finish" the family, It get the circular chain of references error. I have nothing locked or constrained. However, I have been picking the wall in which it is being placed as the work plane for each extrusion. I create an opening, then create a sash, the the glass. They are all touching, and sharing lines. I have tried doing it by offsetting some distance, but to no avail. I have also tried locking the opening to the work plane - wall, but nothing going. Then I tried locking sash extrusion to opening and glass to extrusion, but same error. Nothing seems to work and it is a problem I encounter in all files, not just this one.
    The rotated window in the image is before "finish" family.
    To make things worse, it flexes fine.
    Active Member wildcat_714's Avatar
    2015-10
    PA
    53
    Default Re: In Place Family Circular Reference Error
    This family should be what you need. At the moment its just a cut opening, but it works so all you need to do is put the trim and other pieces in. If you have problems with that just let me know and Ill finish it for ya'.
    Peter-
    2005-05
    TX
    447
    Quote Originally Posted by wildcat_714
    Peter-
    This is needed in version 8.0.
    2015-10
    PA
    53
    My bad, sorry about that. I had forgotton which version I had open. This ones done in V8 release 20050509_2300
    p-
    2005-05
    TX
    447
    Thanks. It works great.
    2003-05
    Northbrook, IL
    879
    Quote Originally Posted by info.87299
    ... However, I have been picking the wall in which it is being placed as the work plane for each extrusion. ...
    This is most likely the source of your error. If you encounter this error in the future when creating an in-place family try the following. Create a reference plane at the face of the wall. Use the reference plane as your working plane.
    2005-05
    TX
    447
    Quote Originally Posted by bclarch
    Thanks for the tip. I will give that a try. I had some ref. planes, but only for the sides of the window for flexing.
  1. Serious error trying to edit in-place family
    Last Post: 2010-09-08, 02:51 PM
  2. In-place family with opening cut - first fatal error in a LONG time
    Last Post: 2010-04-08, 07:09 PM
  3. Place detail/section reference cuts on legends that would reference existing details
    Last Post: 2007-09-28, 08:44 PM
  4. circular reference error
    By Tea_Berries in forum Revit Architecture - General
    Last Post: 2007-09-14, 07:00 PM
  5. Circular Reference Error Message
    By DanielleAnderson in forum Revit Architecture - General
    Last Post: 2006-02-23, 01:38 PM
