I am trying to find a simple way to create an array (which is actually just one perpendicular line offset about 100 times) along a single polyline path at a given offset. This would be similar to the EXTRUDE command along a polyline path, only 2D.
I want the perpendicular line's midpoint to follow the polyline and rotate the line so it remains perpendicular to the polyline. Each perpendicular line will be offset from each other at the same distance along the polyline.
I could mathematically figure out how many lines I would have in each segment and then divide and create the lines, but I am looking for a way that doesn't require excessive boredom and clicking.
Thanks in advance for those that reply.
