Results 1 to 10 of 10
Thread: LDD 2005 elevation precision
    2005-02
    15
    Default LDD 2005 elevation precision
    The grading base drawing is set up to display an elevation precision of 2 decimal places. On screen it is also displayed as 2. However when each individual grading plan that xreferences the grading base is opened, the elevation precision appears as 3. The settings in all drawings is confirmed to be 2 decimal places. Also when a drawing appears to display two decimal places for its elevations it plots out as 3 decimal places. This has been a reoccuring problem and most obvious solutions have been exercised. I am still in search of a solution.
    I could stop if I wanted to Ammon's Avatar
    Salt Lake City, Utah
    423
    Default Re: LDD 2005 elevation precision
    Quote Originally Posted by ebulgaretti
    I'm a little unclear as to what exactly the problem is. How does the elevation precision problem present itself? Is it in the contours, on a profile, in a vertical alignment, in the site grading report of cut and fill?
    More info please.
    2005-02
    15
    The actual grading AECC point object on a grading plan displays as having two decimal places but when plotted it reverts to three decimal places.
    423
    Open up your drawing setup dialog box.
    Project>Drawing Setup ...
    Units tab.
    What is the precision on Elevation?
    Is it 3?
    Try changing that if it is. If you've tried that, I'm not sure what to tell you. Sorry.
    2005-02
    15
    I have tried that, but still i get the same problem.
    423
    Can you attach a screen shot of what you are talking about?
  1. Help With Contour Labeling Elevation Precision
    By aspencer.226869 in forum AutoCAD Civil 3D - General
    Last Post: 2010-08-13, 09:26 PM
  2. Elevation Label Precision
    By Raulmjr in forum AMEP General
    Last Post: 2009-02-12, 05:02 PM
  3. AEC precision vs Acad precision
    By jason.bell in forum CAD Management - General
    Last Post: 2008-02-25, 08:59 PM
  4. elevation precision - LDD 2i
    By sjalbert in forum Survey - General
    Last Post: 2004-10-22, 03:20 PM
