Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Parametric louvers in curtain panels?
  1. #11
    AUGI Addict truevis's Avatar
    2004-07
    Massachusetts, USA
    1,191
    Default Re: Parametric louvers in curtain panels?
    Quote Originally Posted by david.fannon
    ... I made a new curtain wall type called "Louvers" which has the fin as the interior mullions and a simple frame for the perimeter and nothing for the panels. I used has type-driven dimensions to keep the spacing of the fins. Once this type is embedded in a larger curtain wall, it automatically gets the spacing, adding and removing mullions (fins) as required...
    Classic example of good technique and of how to approach Revit -- don't get stuck & obsessed when one way you think of doing something doesn't work. Do it another way.
    david.fannon's method would probably also work with your panels as the louvers instead of the mullions as louvers.
  2. #12
    I could stop if I wanted to Adam Mac's Avatar
    2004-06
    Darwin NT
    319
    Smile Re: Parametric louvers in curtain panels?
    Thanks for taking the time out to "record" it for us David!
    Now that you've added a solution to this thread it's changed from being a dead-ender to a very helpful piece of information.
    Thanks again.
  3. #13
    All AUGI, all the time archjake's Avatar
    2003-07
    Tucson, AZ
    531
    I know this is an old thread, but I was hunting around for other ideas and I hit it. I figured I would record a different approach here for posterity. When I had this issue I used a custom mullion profile to create my louver fins. I made a new curtain wall type called "Louvers" which has the fin as the interior mullions and a simple frame for the perimeter and nothing for the panels. I used has type-driven dimensions to keep the spacing of the fins. Once this type is embedded in a larger curtain wall, it automatically gets the spacing, adding and removing mullions (fins) as required. Worked pretty well for us.
    Would you mind posting an example of this?
    Jake Boen, Architect
    www.InPlaceArchitecture.com
    www.BIMproductivity.com
    Tucson, Arizona
  4. #14
    I could stop if I wanted to Phil Read's Avatar
    2003-05
    Charlotte, NC
    398
    This is a fine solution that takes advantage of the fact that you can exchange curtain panels for curtain walls. Basically 3 steps:
    1. Create Louver profile, load into project and associate with custom Mullion Type.
    2. Associate custom Mullion Type with new custom Curtain Wall. In this wall, specify Horizontal separation between the 'Louver Mullion' (in the attached file - the distance is 4") and set Panel Type to 'Empty System Panel:Empty'.
    3. Select any curtain panel and exchange for the custom curtain wall containing defined louver profile.
    See attached.
    Regards -
    Phil
  5. #15
    2005-07
    3,250
    Thumbs up Re: Parametric louvers in curtain panels?
    I missed this thread in the past, but somehow I did use David's approach recently (custom curtainwall with Empty panel and custom mullion profile as louver). Phil, this is a very elegant solution to adding louvers inside a curtain wall and doesn't fall under "workaround"
  6. #16
    2004-12
    New York, NY
    20
    Just ended up messing around with this today and figured it out using standard family creation methods, although Phil's solution is a nice one.
  7. #17
    2004-08
    10
    I have to thank you profusely for this. Your example helped me figure out the one problem with arrays in curtain panel families. David's solution (Phil just restated it, I think) is good for a basic louver panel but not for more complex designs.
  8. #18
    2010-07
    While this is adding to a very old post, I have taken what I learned and developed a curtain panel louver based a little off the previous curtain panel louver but with the ability to keep the louvers evenly spaced apart. The formula was the part that was giving me the troubles, and I had to work backwards from the previous family.
  1. Parametric Louvers
    By TerribleTim in forum Revit Architecture - General
    Last Post: 2010-05-08, 02:32 AM
  2. Create Louvered Doors with Parametric Louvers
    By awilliams in forum Revit Architecture - General
    Last Post: 2009-11-03, 12:40 PM
  3. Parametric register grilles and louvers
    By rb.72855 in forum AMEP Wish List
    Last Post: 2009-05-14, 01:16 PM
  4. How'd They Do That? - Parametric Louvers
    By bradg in forum AMEP General
    Last Post: 2009-01-21, 03:28 PM
  5. Parametric Louvers
    By beegee in forum Revit Architecture - Families
    Last Post: 2006-10-15, 02:55 PM
