Thread: Window appears when opening a drawing - Select Shape file
    Retired Forum Staff Rico's Avatar
    2005-06
    In the hospital cuz of my fever for more cowbell
    1,828
    Default Window appears when opening a drawing - Select Shape file
    Can anyone tell me what is happening when I open my CAD drawing? I've attahed a pic to help you out cuz I can't quite explain it.
    [SIGPIC][/SIGPIC]
    Return of the Cowbell
    Turlock, CA
    6,409
    Default Re: Window appears when opening a drawing - Select Shape file
    The dwg probably contains a custom linetype that uses a shape in the shx file that its looking for, but you don't have the shx file in the search path. If you recieved the file from someone, you need to ask them to send you all the support files. Teach them to use eTransmit instead of just giving you the dwg.
    C:> ED WORKING....
    LinkedIn
    2001-05
    Austin, TX USA
    2,201
    I agree with Ed that they should use eTransmit to send you the files.
    You can just hit cancel and go on for the time being. The drawing will still look right and you will still be able to use that linetype for newly drawn lines. Its just an annoyance when you open the file.
  1. Replies: 11
    Last Post: 2012-08-21, 02:28 PM
  2. Prevent "Select shape file" window whenever I open a DWG file
    By dgotto in forum AutoCAD LT - General
    Last Post: 2006-11-14, 05:14 PM
  3. Missing Shape Files / Select Shape File
    By Mac Demer in forum AutoCAD General
    Last Post: 2006-11-05, 01:36 PM
  4. Open drawing file - "Select Shape File" message appears
    By gdgutie in forum AutoCAD General
    Last Post: 2006-02-07, 05:48 PM
