Results 1 to 8 of 8
Thread: How to attach a wall to a ramp?
    I could stop if I wanted to E-Key's Avatar
    2005-04
    Russia
    240
    Question How to attach a wall to a ramp?
    Hi everybody!
    I need to connect the top of a wall to the bottom of a curved ramp. I can't find tools to do that in Revit. Any help will be appreciate.
    Thanks.
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,439
    Default Re: How to attach a wall to a ramp?
    There is no specific tool that does it automatically. You can create a sloped floor for a ramp, then you can attach to it. Or you can in section place a sloped ref. plane that follows your ramp slope then attach the walls to that plane.
    Scott D. Brown, AIA
    Project Coordinator | Director of Building Information Modeling
    HHCP.com
    2005-04
    Russia
    240
    Quote Originally Posted by sbrown
    I think it's not the way I want.
    Reference plan is a flat surface, but I need a attach wall to spiral surface.
    2003-05
    Coast to Coast
    4,439
    You can't really do that perfectly, you can fake it pretty well with a series of ref planes, or you can add a railing to your ramp and use a profile the size of a wall for the rail, this will give you a spiraling wall. Then just make it tall enought to overlapp your wall, you will have to use the linework tool to clean up the overlapping lines, but it will render properly.
    Scott D. Brown, AIA
    HHCP.com
    Member Gatchy's Avatar
    2006-01
    Toronto
    24
    Is there a way to hide a wall underneath a ramp? The wall extends past the width of the ramp and can't get it to display as hidden.
    2005-04
    Russia
    240
    Quote Originally Posted by Gatchy View Post
    You can edit the wall's profile.
    2006-01
    Toronto
    24
    I've tried that and did notice it works in certain instances but not all for some weird reason. I tried adjusting the view range but that didn't make a difference. I will be sure to use floors in the future instead of awful ramps. I ended up using a mask region for that specific instance.
    Thanks
    2005-04
    Russia
    240
    To Gatchy
    A ramp doesn't show walls under it with hide lines. After edit profile you can use a Linework tool and assign Hide Lines of <Invisible lines> for the part of the wall under the ramp. I believe it is better way then use a mask region.
  1. curved rail and wall - can't attach wall
    By CADMama in forum Revit Architecture - General
    Last Post: 2009-06-04, 09:02 PM
  2. Attaching an arc wall to an arc ramp (RAC2008)
    By ricardo.o.maciel in forum Revit Architecture - General
    Last Post: 2008-04-05, 10:48 PM
  3. wall above ramp
    By Cheuk Ling in forum Revit Architecture - General
    Last Post: 2007-01-11, 12:16 PM
  4. Spiral wall alongside curved ramp
    By pfrederico in forum Revit Architecture - General
    Last Post: 2005-03-22, 11:32 AM
