Results 1 to 8 of 8
Thread: view scale
    All AUGI, all the time Les Therrien's Avatar
    2003-05
    Tecumseh, Canada
    623
    Default view scale
    I could have sworn i did this before, if not then maybe it was ADT or something?
    Anyways is there a setting where I can change the standard view scales?
    I know I can do a custom scale as a 1: xxx. But I'm more looking to change the defaults.
    I want to use a 5/32" = 1'-0" scale.
    AUGI Addict Joef's Avatar
    2003-12
    Victoria, BC
    1,273
    Default Re: view scale
    Les you are crazy to use that scale . !
    You can set the scale to whatever you want but it has to be an integer. It won't allow 1 to 76.8.
    You just select the scale in bottom corner of the viewport and go to custom. Set the scale (1:XXX) then you can set the display name (15/64 = 1'-0") or whatever. You have to do this for every view that you want to use this scale.
    I'm not sure if this is any help...
    All AUGI, all the time kathy71046's Avatar
    2004-07
    Perth Australia
    736
    I'd also like to know this as unfortunately the custom scale won't allow for 2:1 (or any blowup scale)
    Kathy Taylor
    Senior Structural Draftsperson & Proprietor
    TaylorCAD
    www.taylorcad.com.au
    I don't suffer from insanity - I enjoy it!
    Revit User Phase 3, 4, 5, 4, 3, 5, 4.....
    2003-05
    Tecumseh, Canada
    623
    Quote Originally Posted by Joef View Post
    LOL!
    It's just because I'm trying to get something as large as possible on the sheet set.
    1/8" is too small and 3/16" is too large for the space I have.
    Thanks for the help!
    AUGI Addict aggockel50321's Avatar
    2003-05
    Waterville, Maine
    1,748
    It seems you see these odd scales more often now with the cad evolution.
    It's funny to watch the ol' paper & pencil guys read the drawing scale, and then sit there in puzzlement, twirling their triangular scales, and do things like "5/32"??, Let's see, if I take it off using 1/8" and then multiply the result by 1.5".....
    2003-12
    Victoria, BC
    1,273
    Quote Originally Posted by Les Therrien View Post
    LOL!
    When this happens to us (which isn't very often) we usually try to convince the client that they don't need such a big house!
    Joe
    2008-03
    Wolcott, Connecticut
    104
    Smile Re: view scale
    5/32 would be a pain for anyone who needs to scale the drawing. I would stay away from it unless you like to hear a funny ringing noise in your ears every time a contractor needs to scale the drawing. Usually a bad word followed by the word architect.
    2001-12
    1,714
    Quote Originally Posted by john_a_rosa2 View Post
    But don't the general notes specifically say "DO NOT SCALE DRAWINGS"? If we really believe that note, why do we show the scale? And if we show the scale and tacitly condone scaling the drawings, why don't we just abandon the contradictory note?
    That said, if '1/8" is too small and 3/16" is too large for the space I have', I think I would put the drawing on a sheet alone and use 3/16", or break it into dependent views at 3/16" on two sheets, or remove a few things from that sheet to make room for the view at 3/16". And when all else fails, bump up to the next sheet size and see where I could consolidate some things onto fewer sheets.
    Gordon
  1. Hatch Scale of Detail View Created from a Section View
    By Wish List System in forum Inventor Wish List
    Last Post: 2014-02-25, 11:58 AM
  2. 2013: View Scale, No Scale
    By tcrawford1978 in forum Revit Architecture - General
    Last Post: 2012-11-15, 04:18 PM
  3. Tag for View name & View scale on section views
    By haldier7 in forum Revit Structure - General
    Last Post: 2009-04-23, 11:48 AM
  4. Breakline symbol - Scale with the view scale?
    By scowsert in forum Revit Architecture - Families
    Last Post: 2007-09-17, 05:26 PM
  5. View Title family and View Scale
    By Adam Mac in forum Revit Architecture - Families
    Last Post: 2007-01-23, 10:39 PM
