Results 1 to 7 of 7
Thread: Tapered plywood web joist?
    2003-08
    Ann Arbor, Michigan
    121
    Question Tapered plywood web joist?
    I am trying to modify the plywood web joist family to create a tapered version.
    Is this possible? Are tapered beams possible?
    TrusJoist (and perhaps others) manufactures such a joist for roofs. The bottom is level and the top slopes.
    Thanks for any help.
    Mike
    Revit Arch. Wishlist Mgr. Wes Macaulay's Avatar
    2003-05
    Vancouver, BC CANADA
    3,348
    Default Re: Tapered plywood web joist?
    This is certainly possible... you could probably make a beam family that allows you to draw it like the other beams in the Revit library.
    100 Club Scott_Bloss's Avatar
    2003-11
    Syracuse - New York
    186
    Mike, this is possible! open the family and add height parameters to the end of the joist and then you will be able to control the tapper
    2003-11
    Syracuse - New York
    186
    Mike i am building one for you now but have to run to a meeting will post it for you when i finish
    2003-08
    Ann Arbor, Michigan
    121
    Thank you Wes & Scott for your replies.
    I tried doing what you suggest, Scott, and I got an error message saying "Dimension overconstrains the Family". I noticed that when I select the top member that the bottom one is selected too. The web stays unselected.
    Mike
    2003-11
    Syracuse - New York
    186
    Mike,
    Here you go sorry i did not get it done for you on Friday.
    2003-08
    Ann Arbor, Michigan
    121
    Thanks Scott!
  1. Double Joist Family from default open wood joist?
    By 3dway in forum Revit Architecture - General
    Last Post: 2012-06-08, 03:51 PM
  2. Exporting existing joist - joist material to blame?
    By BecFra in forum Revit - Plotting/Printing/Exporting
    Last Post: 2009-01-28, 08:17 PM
  3. Tapered joist / joist girder?
    By patricks in forum Revit Architecture - Families
    Last Post: 2007-06-20, 01:47 PM
  4. Tapered Joist
    By philipnoland in forum Revit Architecture - General
    Last Post: 2005-08-18, 05:57 PM
  5. Tapered plywood web joist?
    By mikemck in forum Revit Architecture - General
    Last Post: 2005-08-15, 01:59 PM
