Thread: Sliding door vs wall
    2005-03
    70
    Default Sliding door vs wall
    Hi there!
    I've just built a sliding door and it works fine, but if I try to change the thickness of the wall beyond the initial wall thickness in which I made the door all hell breaks lose!
    Well, not that much, hehe, but the door gets messed up if I change the wall thickness. I have another sliding door, less complex than this one and it works fine. I tried to compare both but I can't find out what's wrong with this one.
    Can someone, please, help me?
    I could stop if I wanted to Rhythmick's Avatar
    2004-03
    Colorado
    323
    Default Re: Sliding door vs wall
    I locked dim parameters to the side of the wall so when the wall thickness changes the door moves with the o.s. of wall.
    2005-03
    70
    Thanks mate! I was actually thinking of going building the door anew. So thank you very much!!
  1. Curtain wall sliding door panel
    By jeff.95551 in forum Revit Architecture - Families
    Last Post: 2016-03-12, 03:35 PM
  2. Double Sliding Door Curtain Wall Panel
    By craighowie in forum Revit Architecture - Families
    Last Post: 2011-11-28, 11:54 PM
  3. Curtain Wall- Sliding Door
    By brd in forum Revit Architecture - General
    Last Post: 2008-07-03, 06:29 AM
  4. Sliding door panels, curtain wall families
    By MedJohn in forum Revit Architecture - Families
    Last Post: 2006-09-09, 01:56 AM
  5. Sliding door panels, curtain wall families
    By MedJohn in forum Revit Architecture - General
