I need to do the same but With XCLIP command
An XCLIP Boundary with a Hole cut out...
anybody know how?....
Thanks
Thanks
Hi
Please note I have *split* your post from thread "Floating Viewport with a hole cut out...", plus *moved* from the "AutoCAD Tips & Tricks" forum to this one as I feel this particular forum is a more appropriate place for such a topic.
Thanks, Mike
Forum Moderator
Hi
Check out the following Technical Document on the Autodesk web site under the Knowledge Base section -
ID: TS49277 - Use XCLIP command to remove middle or inside section of xref
Have a good one, Mike
