Thread: Rendering with phases
    2003-09
    California
    400
    Default
    I'm working on a house remodel, and I'm using "Existing" and "New Construction phases". When I go to render the project, the "Existing" just shows up as a grey color. How do I go about getting it to render as if it was all new?
    Any thoughts would be greatly appreciated.
    2003-05
    5,153
    Default Re: Rendering with phases
    You need to adjust your phase filter, so that existing is dispalyed "by category" and other phases are not displayed.
    If that causes problems with other views of the existing, it may be best to make a new phase filter , called say "presentation" for that view.
    Bruce Gow.
    Karel*CAD. Application Specialist..
    Architect.
    Revitalize. Blog
    Super Moderator blads's Avatar
    2003-05
    South Australia
    2,243
    You're a bloody legend beegee!
    that tip is worth its weight in gold
    thanks!
    Cheers @blads
     Mac Geek | Building Design Suite Premium 2014 | Multi-award winning Building Designer | HERS Assessor | AEC Applications engineer
    All AUGI, all the time Allen Lacy's Avatar
    2003-04
    Richmond, VA
    545
    There is a filter called "Show Complete". It shows existing and new construction, but demolition is not displayed. That usually works for me.
    2003-09
    California
    400
    Thank you beegee and Allen for responding. Both of your suggestions work great! Thank you.
  1. Phases
    By wags5116 in forum Revit MEP - General
    Last Post: 2011-06-07, 07:00 PM
  2. Phases
    By rafterman in forum Revit MEP - General
    Last Post: 2006-07-10, 02:14 PM
  3. Replies: 4
    Last Post: 2005-10-18, 12:58 PM
  4. Rendering Hangs (was Rendering Issue)
    By cek in forum Revit - Rendering
    Last Post: 2005-06-06, 11:38 PM
  5. Phases
    By cgrover in forum Revit Architecture - General
    Last Post: 2004-06-09, 10:01 PM
