Is this a display order issue? Why is it, on this floor only the floor pattern seems to show through the walls. Does not happen on other levels, and the view range is set similar to other floors.
Brian
Brian
Check your underlay setting, it should be none, ( but may be set to show current level )
also make sure you are in hidden line mode, not wireframe.
