Thread: Upgrade/Installation Problems.
    2005-07
    7
    Question Upgrade/Installation Problems.
    Background: We have multiple networked floating licensed versions of 2002 that we are upgrading to 2006. We have developed a prototype installation and configuration that we are evaluating by installing a trial version of AutoCAD 2006 on several production machines to acquire feed back from the production architects. We are loading from the AutoCAD 2006 CD. Test computers are Dell PWS running Windows XP SP2.
    Problem: The express tools do not properly load. I realize that express tools is not supported. However, it is on the disk and we use it. This install problem is not consistent. Sometimes, but not every time the installation fails when you run AutoCAD for the first time. I have to remove and reinstall the entire AutoCAD package. Sometimes a couple reboots solves the problem. At least once it effected the AutoCAD 2002 version, and several times now, I can't get it to work at all.
    Question 1. Is there an express tools setup that would permit me to reinstall just express tools.
    Question 2. Anybody know why this is a problem. The specific message I am getting is **Express Tools** - Unable to load aceauto.lsp/fas bad argument type: consp “arctext”.
    Question 3. If Autodesk doesn't support Express tools, but includes it on the disk, who does support it?
    2005-05
    Kansas
    11
    Default Re: Upgrade/Installation Problems.
    Long story short yes you can reload just the express tools. I had to do that once on my machine, for some reason it worked fine on everyone else's. I believe if you put the CD in and go to Load/Unload you can reload express tools from there. There is a few steps that I know I forgot about but it seems like it is in the Repair AutoCAD. Currently I'm running a batch DWG to DWF converter so I can't check the steps. I will check back later and see if you need me to go through the steps.
  1. Revit 2010 Installation problems
    By iankids in forum Revit Architecture - General
    Last Post: 2009-09-18, 07:27 AM
  2. Installation Problems - Can't upgrade
    By dpasa in forum Revit Architecture - General
    Last Post: 2007-06-28, 02:29 PM
  3. Revit 9 Installation problems
    By WolffG in forum Revit Architecture - General
    Last Post: 2006-04-21, 01:31 PM
  4. ABS 2006 installation problems on XP64
    By chris.67534 in forum AMEP General
    Last Post: 2005-06-29, 04:50 AM
  5. Central File Upgrade Problems
    By cphubb in forum Revit Architecture - General
    Last Post: 2004-01-22, 12:01 AM
