Thread: Working with Images - OUT OF MEMORY - Shutting Down
    2004-08
    Iron Station, NC
    3,198
    Default Working with Images - OUT OF MEMORY - Shutting Down
    Does anyone know how to reduce the amount of memory it takes to view a raster image without reducing the quality of the image, we have a project that contains 56 aerial photographs, that are 5000 X 5000 pixels. We can open the file and see small areas, but if we zoom out past a certain point, AutoCAD displays an error message (OUT OF MEMORY - Shutting Down). Any Suggestions, I am using regular AutoCAD 2005.
    Thanks
    100 Club murrayc.49304's Avatar
    2003-03
    158
    Default Re: Working with Images - OUT OF MEMORY - Shutting Down
    Aside from the obvious of UNloading the images (which takes up valuable memory to UNload & REload), you may want to look at simply putting the images on separate layers and simply freezing them.
    Or...
    Find some way to make one master image file, and then IMAGECLIP out the parts you don't currently need
    0,0,0 The Origin
    8,570
    and, of course, install more RAM - or increase your pagefile size.
    2004-08
    Iron Station, NC
    3,198
    I've got 2 Gig and the Page file is set at 4 gig, the images range from .5 meg to 4 meg
  1. Limiting Linked File Loading - Working Memory
    By wmullett in forum Revit - Platform
    Last Post: 2008-03-26, 03:49 AM
  2. Plotting, memory error, file w/SID images
    By kcarlsen in forum AutoCAD Civil 3D - General
    Last Post: 2008-01-11, 04:47 PM
  3. Out of Memory Shutting Down
    By Aquaserpent in forum AutoCAD Plotting
    Last Post: 2005-10-12, 07:17 PM
