Results 1 to 9 of 9
Thread: facets on an rendered arc, curve
    2005-08
    3
    Default facets on an rendered arc, curve
    I have a CAD file that has plenty of facets in the pre-rendered view but once I render the circle or arcs in my view they all revert to 8 facets. I used the sys. variables facetres, revsurf and the CAD options box and set arc segments to 500 for all with no avail once rendered. It looks really bad.
    Any suggestions?
    0,0,0 The Origin
    8,028
    Default Re: facets on an rendered arc, curve
    Look up the variables "surfu" and "surfv", increasing their values will probably help.
    John B
    "With or without religion, you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion." - Steven Weinberg.
    2005-08
    3
    John,
    I have already boosted those values. I still have no idea. Thank you.
    0,0,0 The Origin
    8,028
    Looking at it sideways - how many colours is your windows display set to? The higher the number the better shaded/rendered views look.
    John B
    2001-03
    13,499
    Hi "malaalo" (Sorry, I don't know your real name)
    Please note I have *moved* this thread from the AutoCAD Tips & Tricks forum to this one as I feel this particular Forum is a more appropriate place for such a topic.
    Thanks, Mike
    Forum Moderator
    0,0,0 The Origin
    8,028
    Quote Originally Posted by malaalo
    Any suggestions?
    Hi again.
    Rereading your message (in daylight now) I'm not sure if you are talking about 2d or 3d objects.
    You mention arcs and circles (2d objects) so setting Whiparc to 1 might help.
    You also mention facetres, refsurf, etc which relate to 3d objects.
    John B
    2001-03
    13,499
    Quote Originally Posted by johnbogie
    Hi
    It would be good if "malaalo" (Sorry, I don't know your real name) posted an example drawing file so we can see the issue / problem first-hand...
    Have a good one, Mike
    2005-08
    3
    Mike,
    I tried everything, splinesegs, isollines, facetres, revsurf, rulesurf, tabsurf, dispsilh, surftabu, surtabv, tesselelization, segments per arc or curve...everything. I tried to render another similar situation on a seperate drawing and for some reason it worked out just fine. Originally the view was great all the way up to gourded shade providing a perfect circle and arc, once rendered it would revert back to 8 segments. On another drawing with the same cad it worked out just fine, spheres circles and arcs would recongnize the 200 segments variable....go figure.
    Thank you,
    Mark
    Active Member hofe_design's Avatar
    2005-08
    North Lincs, England
    56
    Have you also tried the VIEWRES command and set it to 20000???
  1. Rendered Walkthrough
    By crarchitect in forum Revit - Rendering
    Last Post: 2009-04-07, 07:58 PM
  2. Shine on rendered curve
    By CAtDiva in forum ACA General
    Last Post: 2007-12-20, 11:41 AM
  3. How to turn of facets when plotting cylindrical model from Paperspace
    By shawn.bean in forum AutoCAD 3D (2006 or below)
    Last Post: 2007-04-18, 06:44 PM
  4. Too Few Facets in Tube Cuts
    By brakware in forum Revit Architecture - General
    Last Post: 2007-03-05, 04:06 PM
  5. 2D Rendered Elevation
    By bskripac in forum AutoCAD Gallery
    Last Post: 2005-03-30, 03:22 PM
