I notice in 8.1's open dialog box that I may now audit Revit files for corrupt data. Not that there would ever be corruption involved with building projects, but has anyone fixed some problems with this feature yet?
Scott D. Brown, AIA
BECK
No problems. I'd just like to hear of problems that it has or could have fixed.Originally Posted by sbrown
The Factory has recommended that all projects being upgraded to Revit 8.1 be audited upon opening the first time in 8.1.
Also, they recommend regularly auditing files. This audit will find corrupt or potentially corrupt data and fix it.
Audit has meaning only for files that use worksets. It forces Revit to open and regenerate all elements. By doing this, elements that cannot be regenerated are uncovered at a time when they can be deleted without corrupting the file. In normal workset operation, elements are not regenerated until they are touched in some manner. This greatly improves performance. Unfortunately, if a bad element is found after you have been working on the file for even a short time, a regeneration failure can cause the file to fail. Before Audit, it was nearly impossible to find the bad element. You were forced to backtrack through backups until one without the offending element was reached.
Thanks for the Audit clarification, David!
Makes much more sense now...
Brad
What kind of things might have caused an element to become bad? Could they be born bad?Originally Posted by David Conant
I'm assuming you would audit the central file, not the local....correct?
Ow! <holding hand over eyes> Make it go away!Originally Posted by truevis
