Thread: point code descriptions
    2005-03
    Indianapolis, IN
    5
    Default point code descriptions
    I've received alot of help from this forum, so I'm hoping someone can help me with this.
    I have an autolisp routine that converts survey points to text that shows a station, an offset, and a description. The problem I'm encountering is that I am missing the coding that links our survey points (which are whole numbers ie - 5, 20, etc) to the descriptions (ie - tree, fire hydrant, etc.). In the lisp routine that I have, the file that contains the coding between points and descriptions is named topocode.001. I do not have this file. I have point codes and descriptions, so I need to know how this coding file is to be written that links the points and descriptions. If anyone could help with this, I'd appreciate it.
    I've attached a screen print in Microsoft Word 2003 format that shows the lisp routine I'm working with and the missing topocode.001 file that links the point code descriptions.
    James Swick
    2002-05
    5
    Default Re: point code descriptions
    Save the topocode.001 file such that the first character of each line starts with the code and the eleventh character of each line begins the description.
  1. Point Descriptions - Multiple Edit
    By Spokes in forum AutoCAD Civil 3D - General
    Last Post: 2009-10-02, 07:59 PM
  2. Point code Dynamic Lookup
    By NathanB in forum Dynamic Blocks - Technical
    Last Post: 2009-10-02, 05:25 PM
  3. Layer Descriptions
    By cadconcepts in forum AutoLISP
    Last Post: 2007-10-17, 09:26 PM
  4. Revision descriptions
    By Chad Smith in forum Revit - In Practice
    Last Post: 2006-10-03, 05:07 PM
  5. Long point descriptions hang surface generation (LD2004)
    By sinc in forum Land Desktop - General
    Last Post: 2004-06-09, 11:55 AM
