Thread: Loading profile for railing editor
    100 Club dgraue's Avatar
    2004-06
    Santa Monica, CA
    184
    Default Loading profile for railing editor
    I have loaded a new profile into my project but when I go to my rails editor, that profile is not one of the options to select from the pull down. I simply modified a rail profile that was an option and I saved it under another name and loaded it into the project, so I'm not sure what I'm doing wrong. Any suggestions?
    Thanks.
    2004-06
    Santa Monica, CA
    184
    Question Re: Loading profile for railing editor
    What's strange is I've been able to put profiles into the railing editor before. Maybe I'm having a brain fade and I've forgotten a step. Can someone try to load a new profile for the railing command and let me know if it seems to work for you? Thanks.
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,440
    Default Re: Loading profile for railing editor
    post your profile. I have no problem adding profiles, note profiles now have diff. types, so make sure it is a rail profile you started with.
    Scott D. Brown, AIA
    BECK
    2004-06
    Santa Monica, CA
    184
    Ok, this is a glass rail panel I modified from one I created earlier (in 7.0) (see attached).
    I have also attached the new profile.
    Thanks.
    2004-06
    Santa Monica, CA
    184
    I think I've found the problem. Even though you can create a family profile consisting of two separate rectangles (in this case) without a warning or error, you can not use this as a rail profile for some reason. You may only use a single closed loop as a railing profile. You can however use multiple loop profiles for wall sweeps, etc.
  1. changing railing profile
    By kathey1 in forum Revit Structure - General
    Last Post: 2012-08-09, 09:54 AM
  2. Fix railing editor
    Last Post: 2012-06-19, 04:04 AM
  3. Railing Profile Probelm.
    By Paul P. in forum Revit Architecture - General
    Last Post: 2005-05-09, 01:59 PM
  4. Adding Baluster family to railing editor
    By cccm1863 in forum Revit Architecture - General
    Last Post: 2004-01-06, 01:46 AM
