Thread: Revision Cloud
    2002-02
    36
    Default Revision Cloud
    Hello,
    Does the revision cloud still exist with AutoCAD 2006? And if so where can I find it?
    Is it easy to set the width and arc length? I know in the past I always had to set the arc length every single time I wanted to draw a revision cloud in the same drawing.
    TIA
    I could stop if I wanted to Chirag Mistry's Avatar
    2004-06
    Atlanta
    254
    Default Re: Revision Cloud
    try using the command revcloud
    2002-02
    36
    Thank you. So there is no icon unless of course you create one?
    2005-07
    Somewhere in the BIM world
    3,139
    Type CUI at the prompt, then in the bottom left section (Command List) scroll to revision could
    it's also in the draw toolbar
    2002-02
    36
    Thank you I see it.
  1. Revision Cloud
    By rhayes.99001 in forum ACA General
    Last Post: 2010-06-21, 04:56 PM
  2. Revision Cloud Tag
    By blairmack in forum Revit Architecture - General
    Last Post: 2009-06-05, 06:13 PM
  3. Revision Cloud
    By sandeep_koodal in forum AutoCAD Tips & Tricks
    Last Post: 2009-03-24, 03:26 AM
