Thread: Anyone managed a Revit2STL conversion
    2003-11
    New Zealand
    1,116
    Default
    Hello,
    I was wanting to generate an STL file but the rapid prototyping company I was talking to said the Revit generated dwg I sent them wouldn't work.
    Has anyone managed to do a STL conversion? If yes, how did you do it?
    TIA,
    Guy
    2003-05
    5,153
    Default Re: Anyone managed a Revit2STL conversion
    I think "bud" has done it.
    Refer This Topic
    Member cwentworth's Avatar
    2006-03
    Lake Elsinore, CA
    37
    It's easy to convert your Revit file for 3D printing. You output to DWG polymesh. Then bring it into Autocad and save as a vrml. You need the vrml pluggin from www.xanadu.cz to save the vrml file. Then send it to a guy like me! Or if you want me to do it we do it as a service. Here are some samples.
    Chris
    www.3drp.com
  1. Managed Print Services
    By adam_butler8657367 in forum Facilities Management In Practice
    Last Post: 2012-03-13, 05:46 PM
  2. Managed Links
    By paroz in forum 3ds Max - General
    Last Post: 2010-03-14, 11:40 PM
  3. Purging Blocks in managed code?
    By Ed Jobe in forum Dot Net API
    Last Post: 2007-02-06, 11:08 PM
  4. running ADT in a managed enviroment
    By arcadia_x27 in forum Networks
    Last Post: 2005-11-08, 07:31 PM
  5. How are Titleblocks managed with Revit?
    By mbellofatto in forum Revit Architecture - General
    Last Post: 2004-10-04, 11:09 PM
