Thread: Shared Parameter in Project
    2005-03
    26
    Question Shared Parameter in Project
    Hi,
    I don't know if I am doing right or wrong.
    I created a new title block with a shared parameter.
    When I load this title block into the project file, I also need to load shared parameter form settings/parameters/shared parameters to add parameters and check the project information category.
    Am I doing right? Please let me know the right way if I was wrong.
    Thank you
    2003-04
    Irvine, CA
    6,807
    Default Re: Shared Parameter in Project
    Quote Originally Posted by alext
    ...Am I doing right? Please let me know the right way if I was wrong...
    Sounds like you are on the right path...let us know if it works when you are done.
  1. Change Parameter from Project to Shared
    By myBIMhero in forum Revit Architecture - General
    Last Post: 2009-11-12, 11:31 PM
  2. Change Project Parameter to Shared Parameter?
    By kgodfrey in forum Revit Structure - General
    Last Post: 2008-11-12, 03:43 PM
  3. Shared parameter need to be loaded as project parameter?
    By Justin Marchiel in forum Revit Architecture - General
    Last Post: 2006-09-15, 12:39 AM
  4. Project or Shared Parameter with Formula?
    By Haden in forum Revit Architecture - General
    Last Post: 2006-07-18, 09:31 PM
