Results 1 to 6 of 6
Thread: Aligning Multiple VIews on Multiple Sheets
    2004-05
    Auckland, New Zealand
    341
    Default Tip: Aligning Multiple VIews on Multiple Sheets
    I have got approx 10 Floor Plans made up & want to Place them on Multiple Sheets.
    Placing 1 view on 1 sheet is alright, but i want the next Sheet & floor plan to sit in the same position as the previous - so that i can manually overlay the Plotted sheets & they align up
    any suggestions on how to go about this?
    Dwane Stairmand
    2003-05
    5,153
    Default Re: Aligning Multiple VIews on Multiple Sheets
    Make a sheet with setout lines / crosshairs or whatever is needed.
    Align views on each sheet using these guides.
    Swap out these ""aligning sheets '" with the standard sheets, or else use a visibility parameter to turn off the align lines.
    I could stop if I wanted to Shaun v Rooyen's Avatar
    2005-02
    337
    I use the "Work Plane Visibility" in the title block view. By turning this on I have a common grid to work to, thru' all title blocks. You still have to wing it slightly, by moving a corner of the building to a grid intersection.
    2004-05
    341
    Cheers Guys for the response's
    I have a go at doing bath ways
    Dwane Stairmand
    2003-05
    5,153
    Nice tip Zeds !
    ( Scott, you listenin'? )
    Quote Originally Posted by Zeds
    2003-04
    Chino, CA
    4,756
    Zzzzz......Huh? What? What was that?
  1. Printing Multiple sheets of elongated views
    By Mike Hardy-Brown in forum Revit - Hardware & Operating Systems
    Last Post: 2009-09-30, 11:02 AM
  2. Aligning Floor Plans on Multiple Sheets
    By bheng in forum Revit Architecture - General
    Last Post: 2007-01-19, 05:30 PM
  3. Tip: Aligning Multiple VIews on Multiple Sheets
    By d.stairmand in forum Revit Architecture - Tips & Tricks
    Last Post: 2005-09-08, 02:19 AM
  4. open multiple views/sheets
    By Chirag Mistry in forum Revit Architecture - General
    Last Post: 2005-08-16, 10:00 PM
  5. Duplicate sheets & views on multiple sheets
    By Chad Smith in forum Revit Architecture - Wish List
    Last Post: 2005-03-30, 04:04 PM
